Car won't go into gear- 1999 prelude type sh
My prelude wont go into any gear while the car is started. When the car is off it seems to go through the gears just fine. I recently just changed the slave and master cylinders. Then took the car to meinke to get the clutch system bleed because i couldnt bleed it myself. I bought the car with some kind of aftermarket clutch. I think its an ACT but not sure. What could the problem be? I usually turn on the car and start it in first gear and drive it around the inside streets and sometimes I have to force it into gears and go but at times it doesnt go. Also when i come to a complete stop it wont go into any gear even with me trying to shove it in.
Sounds like the clutch is failing to disengage. If you can see the slave cylinder actuate the clutch fork, then it's probably time to pull the tranny and see what's up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch »</TD></TR><TR><TD CLASS="quote">THROW OUT BEARING! or the spring in the clutch assembly
Alright I am suppose to get my clutch in the mail tomm. I am gonna get that changed and hopefully that will do the trick
</TD></TR></TABLE>Alright I am suppose to get my clutch in the mail tomm. I am gonna get that changed and hopefully that will do the trick
Scrap, you IM'ed me for a carfax help but your IM system is down...paypal $5 to racerboy063@aol.com and the vin #. Thanks.
