help with megan silencer
Ok guys i recently bought a used megan exhaust and it only came with piping, muffler, and the silencer and nothing else. So i just get a bolt and put the silencer in(there is only one hole on the muffler to put the bolt in) but it rattles like crazy. By the way there are two holes in the silencer for bolts but only one on the muffler. Guys help me find a way to keep the silencer from rattling! thanks (pics below)
a simple quick fix is to wrap the outside lip of the silencer in elctrical tape and just slide the silencer back in carefully. I personally dont use the silencer bc i have a 22" long mid-steel resonator but yea the sinlencer helps a SHITLOAD. B4 i installed the resonator I did that and had no problems w/ rattiling after that, so give it a try and make sure you keep the tape tight while putting it on.
Hope this helps
Hope this helps
thanks a bunch guys, I just slid a washer in betweend the silencer and muffler where the hole is at and it did the job! WOHOO! omg it almost sounds stock now but when i get on it , IT SOUNDS AWSOME! and i dont feel a difference at all and the car feels quite quick maybe cause I can hear the motor now
thanks again!
thanks again!
Shaguar47
May 11, 2006 05:59 PM
droppedcivo
Apr 22, 2003 09:53 PM
