Vroom boooog no speed 92 ex
Old May 31, 2006 | 11:21 AM
nelsond's Avatar
Default Vroom boooog no speed 92 ex
My friend has a 92 accord and he has no acceleration so he changed the wires spark plugs distubutor and fuel injectors and still no power with his f22a6 when he drives -it bogs
out at 30 and even wants to cut off. when he floors the pedal it gets worse like you here a geo metro running on 1 spark plug trying to go up a hill it seems like a fuel matter and when he goes to second gear it jerks like its out of gas
and he changed to a high flow cat.
so iam lost i say fuel filter is bad cause the car cranks and runs but stutters
help him cause you guys are the pros
Old May 31, 2006 | 11:29 AM
S CARTER's Avatar
Default Re: Vroom boooog no speed 92 ex (nelsond)
Try cleaning the EGR ports
Old May 31, 2006 | 11:30 AM
nelsond's Avatar
Default Re: Vroom boooog no speed 92 ex (S CARTER)
where is that at
Old May 31, 2006 | 11:32 AM
S CARTER's Avatar
This might help out.
http://home.comcast.net/~em-engineering/T2T013.pdf
Old May 31, 2006 | 03:41 PM
nelsond's Avatar
i have a code number 17 from the ecu and i changed the fuel injectors all four and changed the fuel filter what can be left and i also cleaned the egr ports
Old May 31, 2006 | 03:45 PM
BLKFLSH's Avatar
Code #17 = VSS - speed sensor Don't know if that could cause your problem though. Does your cruise control work? (if you even have one)
Kyleinthahonda
Engine Management and Tuning
May 31, 2017 10:13 PM
408DA
Mar 10, 2010 08:44 AM
jonwrong
Oct 8, 2008 07:04 PM
tedog69er
May 19, 2006 01:13 AM
starchland
May 25, 2004 11:27 PM
