RSX vs. EP3 Engines
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hockeyMike2489 »</TD></TR><TR><TD CLASS="quote">Thinking about buying either an RSX or an EP3 and I'm wondering if their is any difference between them?</TD></TR></TABLE>
thinking about night and day and i'm wondering if there is any difference between them?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hockeyMike2489 »</TD></TR><TR><TD CLASS="quote">Sorry guys! I meant is their a difference between the RSX motor and an EP3 motor?</TD></TR></TABLE>
still dont help us, base model rsx or type s
both?
well the base and type S engines have a big difference
ep3 = 160 crank
type S = 201 crank
base = ? i forgot
...but seriously..pick one...BASE OR TYPE S?!
ep3 = 160 crank
type S = 201 crank
base = ? i forgot
Quick & easy article at hondata.com --
http://hondata.com/techk20general.html
FYI: RSX Type-S in 2002-04 had the K20A2 engine. Base RSX and EP3 have the K20A3 engine; base RSX has plastic dual-length intake runners, EP3 has basically the same intake manifold as the Type-S.
There's a lot of info out there -- keep digging and you'll find it.
just another little help for you.
K20A3 comes in the RSX non-S and EP3
k20A2 is the S motor.
the k20a3 claims to have i-vtec but you wont' hear a x-over of vtec because the k20a3 i-vtec system essentially kicks in at around 3000 rpms or something liek that. its basically en economy vtec. what happens is that it stays in "vtec" mode once you pass a certain rpm, so if you were to punch it you will not hear vtec cross over, its like fake vtec i guess you can say..
even putting on i/h/e you won't hear a x-over.
if you want to feel/hear vtec, you have to get the S as that has real vtec.
there's an article floating around everywhere about this information.
it might be even posted up in the ht forums..
good luck though
"go big or go home"
good luck though
"go big or go home"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMcb7 »</TD></TR><TR><TD CLASS="quote">and thank god i picked up a type S :D K20Z1 FTW!!!!</TD></TR></TABLE>
Same here, I would have kicked myself in the *** picking a base model.... I was actually thinking about it too - so I wouldn't be tempted to mod my car
Ok...
the EP3 is the 02-05 Civic Si which has the K20A3 motor...aka fuel ecomony car. It is also the same motor in the base model RSX. Pushing a whopping 160hp. That article from hondata explains things very well, so I won't do it again. They say this motor has iVtec, but not really, a different form of it, and a tricky marketing tool.
So there is no difference engine wise (that you should ever worry about) between the 02-05 Civic Si and the Base RSX. The RSX Type-S (K20A2) has the "performance motor, aswell as the new 06+ Civic Si (K20Z3).
So anyway, hope that answered your question. If you want to know anything else...ask away.
tomlinson619
Apr 12, 2006 12:54 PM
