Brake light?
Old Apr 14, 2002 | 02:41 PM
DR. ON POINT's Avatar
Banned
Default Brake light?
https://honda-tech.com/zerothread?id=164550
Old Apr 14, 2002 | 03:05 PM
neveronlines2k's Avatar
Default Re: Brake light? (On Point EK)
It sounds like bad wiring to me. My friend had a jetta that did the same thing we re-wired it and the problem went away (I think there was a break in one of the wiers). Hope that helps.
Old Apr 14, 2002 | 03:12 PM
Banned
Default Re: Brake light? (stuckatworksi)
what wires?
Old Apr 14, 2002 | 03:32 PM
NevadaSol's Avatar
Have you tried driving in reverse to see if that corrects it?
Just kidding. Sounds like a wiring problem to me, too.
Old Apr 14, 2002 | 03:37 PM
Banned
Default Re: Brake light? (NevadaSol)
how do we get the conclusion thats its wiring? there are no wires envolved in a rear disk conversion?
Old Apr 14, 2002 | 03:49 PM
TurboBumblBee's Avatar
this might be a long shot in the dark.. but check all the bulbs and make sure none of them are burnt out.. i remeber a while ago i put some altezza lights on my old hatch and it did something similar cause i had the reverse light in the brake light spot.. i dont even remember if your systoms were the same as mine but it frustrated me like hell.. also your brake switch under the dash on the brake pedal could have just gone bad..
Old Apr 14, 2002 | 04:04 PM
Banned
Default Re: Brake light? (95CivicEX)
ohh, my ignorance, when I mean brake light I mean the light on the dash (in the guage cluster)
Old Apr 14, 2002 | 05:25 PM
Banned
Old Apr 14, 2002 | 05:36 PM
Shimoba's Avatar
I had that problem in my old Lude, it was a loose wire near the e-brake. I just wiggled some wires and that fixed it.
Old Apr 14, 2002 | 05:51 PM
Banned
Default Re: Brake light? (Shimoba)
*good suggestion- will try tomorrow
any other input?
Old Apr 14, 2002 | 08:48 PM
Banned
TTT
Old Apr 14, 2002 | 09:34 PM
any other input?
definatly try that.. maybe you accidently loosened the wire that is in the ebrake when you put the new cables in for the ebrake..
also make sure you have enough brake fluid in the master cylinder cause if you dont the sensor will pick it up and do the same thing w/ the brake light..
cycoclown
Apr 16, 2007 10:30 PM
91accordwagon
Aug 27, 2006 12:37 PM
Gonzo_SiR
Audio / Security / Video
Jul 19, 2003 02:03 PM
92accord4life
May 2, 2002 02:02 PM
naturalhoosier
Nov 11, 2001 01:08 AM
