how do you remove the attena on an ej1?
i mean theres only two screws that hold it in...but after you loosen that i still cant figure how to get it off of the rod...plus i dont wan to break it.
First, you need to disconnect the antenna under the dashboard and ease the way of the wire until where it enters the a-pillar.
I suggest you put a wire on the bottom, if you plan to replace broken antenna with new one.
You loosen the screws on the roof and pull out antenna, while doing so you will pull wire through to which you can connect the new antenna wire and pull the opposite way.
That really facilitates the entire replacement process.
kristin
kristin
SCMFOX
Dec 21, 2017 09:16 PM
dftram
16
Mar 20, 2013 03:37 PM
