Redid compression test, results look better???
I had a thread before of my compression test and when i did it, i didn't pull my injectors or held it at wide open throttle but was at operating temp. The results from cyl 4 to 1 were 180psi, 175psi, 170psi, and 160psi. I redid my test today at operating temp, wideopen throttle, adn injectors pulled. I got from cyl 4 to 1 200psi, 200psi, 195psi, and 190psi. The result seems way better and what it should be. the car is a 2000 civic si 69k mi, w/ b16a2. Are my new results good and normal????
Si_chRis
15
May 26, 2006 08:46 AM
