jumping in 1st
Old May 31, 2006 | 05:06 AM
stemiched's Avatar
Default jumping in 1st
my crx sometimes jumps and starts like bull rider bucking sometimes when in in 1st gear, doesnt do it all the time and only does this in 1st gear, i dont know what to check.
Old May 31, 2006 | 05:21 AM
mickiemagik's Avatar
Default Re: jumping in 1st (stemiched)
What RPM? Possibly it is simply that you are not in a high enough range. My 90 300zx and 88 civic do taht to an extent
Old May 31, 2006 | 05:44 AM
stemiched's Avatar
Default Re: jumping in 1st (mickiemagik)
havent tooken notice but probably around 2000rpm, this is just going down my driveway so im not reving high.
Old May 31, 2006 | 06:16 AM
'90crxSI's Avatar
My 2002 Saturn VUE does that too...not when your giving it gas, but in 1st gear kinda going on its own power, it bucks a bit, till you give it more gas or less clutch...
Old May 31, 2006 | 06:19 AM
ludesrv's Avatar
It's the weak motor mounts. The gentle push of the engine at that RPM make the engine rock back and forth, after a bit, it will jump around. I get it too. It's fine. Simply get stronger motor mounts and the engine won't rock, but you will feel the vibrations of the engine running more. It's a lose lose situation. Unless you get brand new stock mounts.
Old May 31, 2006 | 06:24 AM
stemiched's Avatar
Default Re: (ludesrv)
alright so pretty much its no problem i just have to deal with it, it doesnt bother me much anyway, just shift into 2nd and its fine anyway so ill just keep doing that.
thanks people for letting me know there is nothing for me to be worried about
soursour
May 20, 2007 08:41 PM
sablan02
Feb 6, 2007 11:48 PM
ch0
May 16, 2005 10:39 AM
3rdgenintegra48
May 1, 2005 06:56 PM
RallySportCivic
Sep 26, 2002 05:38 PM
