ABS LIGHT is ON
Old May 30, 2006 | 08:50 PM
accord23's Avatar
Default ABS LIGHT is ON
My ABS Light comes on..what do I do to get rid of it...does it have to do anything about the Brake fluid?
Old May 31, 2006 | 02:29 PM
96accordtypeS's Avatar
Default Re: ABS LIGHT is ON (accord23)
lol
Old Jun 1, 2006 | 08:10 AM
JimBlake's Avatar
Maybe if you say what kind of car & year, someone will post instructions about how to read the ABS error code.
Old Jun 1, 2006 | 09:08 AM
j-spec_cc2's Avatar
check the fuse and check the ABS fluid...
if those are ok, then we can go further in trying to help you with you problem
Old Jun 1, 2006 | 04:10 PM
8894honda's Avatar
mine (94 ex) had the same problem i just put brake fluid in and it cut off so check the fluid
Old Jun 1, 2006 | 07:29 PM
accord23's Avatar
It's a 95 Accord EX Manual Transmission....
Old Jun 2, 2006 | 09:09 AM
Superorb's Avatar
a 95... i've owned two 95's both auto and 5sp but both ex. the abs motor on the 5th gen accord is prone to dieing at about 10 years old. both of mine were fine until I heard this buzzing, then a few minutes later the light would coem on and buzzing would stop. Turns out that there was a leak in the motor somewhere. bleeding or adding more fluid did nothing. These things just die for everyone, it's just a matter of time. I unplugged the motor and also unplugged the harness to the abs unit by the passenger kickplate. Sometime soon I'm hoping to put some non-abs stuff in there cause the pedal feels squishy, probably form the non-functioning abs.
Old Jun 2, 2006 | 09:22 AM
TheMuffinMan's Avatar
He knows where you live!
And this is why I don't have ABS!
mfrs
Sep 5, 2015 12:32 PM
newhondaowner29
Jan 11, 2006 08:11 PM
seraniko
Sep 8, 2005 01:44 PM
PleaseHelp
Aug 16, 2004 07:45 PM
vain
Apr 13, 2003 12:40 PM
