parking brake light
Old May 30, 2006 | 07:54 PM
skippygsr's Avatar
Default parking brake light
ihave a 2000 db8 my parking brake light comes on after i hit brakes and the brake pedel is spongey.. i just did the rear calipers and it was fine untill i did the calipers i think but im not sure if it is due to not bleeding the brakes proberly
thanks for the help
Old May 30, 2006 | 08:16 PM
95LssTeg's Avatar
Default Re: parking brake light (skippygsr)
You need to bleed your brakes again.
Old May 30, 2006 | 09:12 PM
skippygsr's Avatar
Default Re: parking brake light (95LssTeg)
thanks man
Old May 31, 2006 | 02:00 AM
zeroz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95LssTeg &raquo;</TD></TR><TR><TD CLASS="quote">You need to bleed your brakes again.</TD></TR></TABLE>
and check fluid lvls
Old May 31, 2006 | 06:25 AM
crx_88_si's Avatar
did you remove the brake line from the caliper? if not then you might have a leak somewhere.
Old May 31, 2006 | 09:57 AM
skippygsr's Avatar
Default Re: (crx_88_si)
i bleed the brakes its stopped doing it thanks guys.
Novacoma
Honda CR-V & Element
Jun 28, 2017 01:35 PM
rexfan
36
Aug 31, 2009 11:43 AM
RetarTed
Jan 10, 2006 07:11 AM
HATCHingMN
Feb 24, 2004 09:17 PM
areme
Feb 5, 2004 06:25 AM
