Headlight polishing anyone?
Old May 30, 2006 | 07:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Headlight polishing anyone?
Started polishing my friend's 1998 Civic headlights tonight, these things were nanannnasty!!! They were so yellow and faded that it was downright dangerous to drive at night with these things. I've gont one mostly done so far, here's a comparison:
After wetsanding, before polishing
After polishing
Old May 30, 2006 | 07:18 PM
CRG Motorsports's Avatar
Former Sponsor - Cancelled
Default Re: Headlight polishing anyone? (PatrickGSR94)
Did you use 3M plastic polish after you wet sanded it? What grit did you use?
Old May 30, 2006 | 07:19 PM
arthurcruz1's Avatar
Wow! That looks pretty good, lets see pics of it put on.
Old May 30, 2006 | 07:20 PM
Community Builder
Default Re: Headlight polishing anyone? (JDMSOL81)
Because these were so bad, I had to start with 220-grit, then 320, 400, 600, 800, 1000, 1200, 1500, then finally 2000. Then I used Mother's Metal Polish, then Meguiar's DACP, then P21S on various pads on my Porter Cable buffer.
There are still some light scratches remaining, I'll probably go back again with 3000-grit and polish them again.
Old May 30, 2006 | 07:22 PM
DSEA2's Avatar
i flitz my headlights!! but seriously it look like 5 minutes and they look like new. haha. but this way is probably better.
confidence's Avatar
sweet jesus!!!! i never belived you would be able to make them even halfway usable much less like new!!! and dangerous to drive with those was an undestatement to say the least! i had to get oem fog just to see at night
Old May 30, 2006 | 08:07 PM
LazyDC5's Avatar
i had to do the same thing with my dc5. the headlights were way too nasty. i used 600, 1000, 200, then some of those mothers polish. things came out clean like it was brand spankin new.
Old May 30, 2006 | 08:26 PM
crazi_E's Avatar
Default Re: (LazyDC5)
that came out good
Old May 30, 2006 | 08:38 PM
Halo's Avatar
Can you give us the run down on the procedure? I.E- Sanding in one direction? Heavy or light pressure applied with sandpaper? I did this same thing with my old ep3 and they came out like crap, the sand marks remained after an hour of polishing..Looks great btw
Old May 30, 2006 | 08:41 PM
Community Builder
Default Re: Headlight polishing anyone? (Halo)
Yes I have also done it by hand in the past, for the polishing, but I truly believe the secret is using a powered buffer, a Porter Cable in my case. Also you need to use many grades of sandpaper, and do each successive step in a perpendicular direction from the previous step.
I suppose I used quite a bit of pressure, as my arm got pretty dang tired. I also used a rubber sanding block for the first time, instead of just holding the sandpaper in my hands. That was nice, because in the past my fingers always start bleeding after gripping those sandpapers and working with them for awhile.
Old May 30, 2006 | 09:11 PM
ECKOTYPER's Avatar
just did this to my homes 97 aftermarket headlights used 200 grit, and a 3/4 inch grinder with polishing pad atatchment and turtle wax... they look like new!... needless to say i took apart my jdm headlights for my dc2 to repeat the process
Old May 30, 2006 | 09:17 PM
H.A.R.T B18C1EG6's Avatar
Default Re: Headlight polishing anyone? (snail)
looks good
Old May 30, 2006 | 10:17 PM
cambodian's Avatar
Default Re: Headlight polishing anyone? (H.A.R.T B18C1EG6)
pics of the car?
Old May 30, 2006 | 10:21 PM
PSU's Avatar
PSU
formerly DxHatchback
Default Re: (kageon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kageon1 &raquo;</TD></TR><TR><TD CLASS="quote">Wow! That looks pretty good, lets see pics of it put on.</TD></TR></TABLE>
Old May 30, 2006 | 10:47 PM
B_CRUZ!'s Avatar
I had the same problem with my 96 sedan. I just used rubbing compund on the orbital and finished it off with Plastic-X or something.
Old May 30, 2006 | 11:38 PM
E46Kid's Avatar
Default Re: Headlight polishing anyone? (B_Cruz)
good looken out on your homie
Old May 30, 2006 | 11:44 PM
TSX TEX's Avatar
Default Re: Headlight polishing anyone? (EkSi)
Mothers metal polish
Old May 30, 2006 | 11:45 PM
SD_Lurker's Avatar
HT White Ops
I am working on this myself. Got mine wet sanded just need to buff. BTW looks alot better.
Old May 30, 2006 | 11:47 PM
KOREAN's Avatar
Default Re: Headlight polishing anyone? (nicks_jdmstyle_ef9)
Remember everyone, the Rubbing Compound is the key to having it shiny as hell!
Old May 30, 2006 | 11:54 PM
ECKOTYPER's Avatar
why would u use metal polish on something not metal? yes it takes stains out etc... but regular polish is better suited for this!
Old May 30, 2006 | 11:55 PM
JDM INSPIRED's Avatar
nice
Old May 31, 2006 | 12:28 AM
dreww..'s Avatar
they came out pretty nice
Old May 31, 2006 | 12:31 AM
bluemild85's Avatar
they came out good
Old May 31, 2006 | 01:11 AM
asgqwaeg's Avatar
looks almost new
Old May 31, 2006 | 04:08 AM
Community Builder
Default Re: (ECKOTYPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECKOTYPER &raquo;</TD></TR><TR><TD CLASS="quote">just did this to my homes 97 aftermarket headlights used 200 grit, and a 3/4 inch grinder with polishing pad atatchment and turtle wax... they look like new!... needless to say i took apart my jdm headlights for my dc2 to repeat the process </TD></TR></TABLE>
Did you mean to say 2000 grit? I don't think any polish would take out scratches left by 200-grit sandpaper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECKOTYPER &raquo;</TD></TR><TR><TD CLASS="quote">why would u use metal polish on something not metal? yes it takes stains out etc... but regular polish is better suited for this!</TD></TR></TABLE>
I don't know if it was necessary, but I figured the metal polish was the most abrasive product I had (not sure, now that I have the DACP which I only just recently picked up).
