Honda Idleling Problem
I have a 1992 Honda Civic DX that lopes while ideling when no-one is around the car. Can you suggest any possible fixes for this problem. I just bought the car for my first car and havent really had any expierance with honda's like i have with other vehicles. Please help me.
clean ur IACV with throttle body cleaner..worked for my CX
https://honda-tech.com/zerothread?id=1575913 theres a DIY diff motor..but its in the same spot
vacum is easy. look under your hood there should be a sticker on the underside of your hood. it will tell you what you need to know. but about your idleing problem good luck with that. i did everything and replaced everything. nothing worked. i just learned to live with it, or untill i get a new engine. but good luck. oh one more thing try cleaning out your FITV (fast idle thermo valve).
1. unclip all of your injector clips, one by one remove the electrical from each injector, if the idle steadies with one you need a new injector. (this happened to me)
2. grab a can of throttle body cleaner, spray all around the intake manifold, if you hear a difference you have a vacuum leak that you need to find and fix (also clean your throttle body while your there.
3. in some older v8 and v6 cars if the o2 sensor was bad this was happened so check that.
lastly check your codes see if anything comes up...
InsaneBoost
Jan 4, 2010 08:28 AM
manniakk
Aug 5, 2007 12:29 PM
