Alternator problem.. 13.5-13.7 volts?
Old May 30, 2006 | 04:50 PM
DarkBB4's Avatar
Default Alternator problem.. 13.5-13.7 volts?
I have an odyssey light weight battery and my voltage was around 14.0 (i have an apexi rsm) all the time.. but ive noticed that its a lot lower now.. near 13.5-13.7 all the time... I am going to change my grounds, because i have a feeling theyre kinda lousy... but other than that.. what can i do?!?! is htis a problem?
Old May 30, 2006 | 04:56 PM
petern101's Avatar
Default Re: Alternator problem.. 13.5-13.7 volts? (DarkBB4)
i constantly read 13.4 - 12.8ish (reading off my escort x50)
but that doesn't sound too bad for me. i don't think that .2 drop in volts will make a difference esp. since you were already reading kinda high.
Old May 30, 2006 | 08:37 PM
gooseman's Avatar
my apexi says 12.8 to 13.2v
actual charging volts for a prelude alt should be 13.5 to 14v
so you're ok
Old May 31, 2006 | 11:03 AM
prelittlelude's Avatar
13.5 is normal, i would expect to see it dip lower with accessories on. if you feel its to low, check grounds.. if there is a alt problem it will make a high wining noise as the rectifiers fail. ususally the bat light will kick on if there is even a slight problem in the charging circuit. the ecu keep good tabs on the alt and electronic load detector circuit.
b16_swap
Mar 30, 2011 06:51 PM
instructor74
Jul 8, 2008 06:05 PM
MOVE OVER
Feb 26, 2008 06:15 AM
Hawkrider
Jul 8, 2003 02:53 PM
onyx00
Dec 18, 2002 12:07 PM
