..::Need help with weird electrical cig lighter issue?
Old May 30, 2006 | 04:49 PM
PumaFiveOh's Avatar
Default ..::Need help with weird electrical cig lighter issue?
I'm having a weird issue where my cig lighter works fine with the actual cig lighter unit, but I get no power when plugging in any phone charger or any other electrical device.
Is there a fuse, short or messed up wiring somewhere that could be preventing 12v accessories from working? I just need to know what and where I should start looking at first. I bought the car with an aftermarket deck and EQ installed already, so not sure if during the install of those items something got messed with?
Any advice is greatly appreciated.
Old May 30, 2006 | 05:05 PM
Black Paper Diary's Avatar
Default Re: ..::Need help with weird electrical cig lighter issue? (PumaFiveOh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PumaFiveOh &raquo;</TD></TR><TR><TD CLASS="quote">I'm having a weird issue where my cig lighter works fine with the actual cig lighter unit, but I get no power when plugging in any phone charger or any other electrical device.
Any advice is greatly appreciated. </TD></TR></TABLE>
i would think that if the actual cig lighter is working, then the accessories should work. Have you tried the phone charger in another car to see if thats the problem?
Old May 30, 2006 | 05:12 PM
atg1290's Avatar
Most phone chargers have a fuse of their own at the tip which unscrews..that sounds like the problem.
Old May 30, 2006 | 05:30 PM
98GSRrdr's Avatar
Default Re: (atg1290)
that or ... the metal tip coming out the end isnt long enough .. not touching all the way inside .. u can normaly unscrew it alittle longer so it will touch the inside middle
Old May 30, 2006 | 06:00 PM
PumaFiveOh's Avatar
Default Re: (98GSRrdr)
I've tried two different chargers, and one of those oil-scent heating things and none of them work in my integra. However they all do work in my other cars?
I'll look into the unscrewing thing you guys suggested, but other then that I'm stumped?
Old May 30, 2006 | 06:24 PM
PumaFiveOh's Avatar
Default Re: (PumaFiveOh)
Thanks for your help guys, found the problem. It was just old and crusty.....previous owners must have just used the **** out of it. Had to stick some sandpaper on the end of a screwdriver and go to work. Just needed some de-crusting I guess!
smokecdxx
Audio / Security / Video
Feb 27, 2008 09:52 PM
dean2
Oct 20, 2007 04:20 PM
97civicsedan
Apr 29, 2007 11:57 AM
jp1
May 16, 2006 12:14 PM
fivespeedintegra
Jun 1, 2003 07:30 AM
