Hatch Conversion?
Old May 30, 2006 | 02:20 PM
FGride's Avatar
Default Hatch Conversion?
I just wanted to know does the actual hatch itself from a '99-'00 hatchback fit on a '96 hatchback i want to switch mine so i can get the lock on it and the handle to open it w/o having to use the key
Old May 30, 2006 | 02:54 PM
tha_badguy's Avatar
im pretty sure the hatch itself is the same
but cant u just add the handle with the lock on it
i wanna do this too
Old May 30, 2006 | 03:10 PM
pucancakes's Avatar
Default Re: (tha_badguy)
an alternative is to shave it anyways and add a trunk popper
Old May 30, 2006 | 09:18 PM
FGride's Avatar
i dont know can u just add the handle and lock
Old May 30, 2006 | 09:27 PM
EK k kay's Avatar
Default Re: Hatch Conversion? (batmanEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batmanEK &raquo;</TD></TR><TR><TD CLASS="quote">I just wanted to know does the actual hatch itself from a '99-'00 hatchback fit on a '96 hatchback i want to switch mine so i can get the lock on it and the handle to open it w/o having to use the key</TD></TR></TABLE>
The hatches are the same. None have the trunk pop. You have to get it custom installed.
Old May 30, 2006 | 09:36 PM
. WAAS_SAPPENING's Avatar
Default Re: Hatch Conversion? (EK k kay)
they are the same you should have no problem installing a '99-'00 hatch onto to your '96-'98 hatch. But why do all that when you can just swap out the handle and lock.
Old May 30, 2006 | 09:39 PM
pucancakes's Avatar
Default Re: (batmanEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batmanEK &raquo;</TD></TR><TR><TD CLASS="quote">i dont know can u just add the handle and lock</TD></TR></TABLE>
i know i can. the question is: can YOU?
Old May 30, 2006 | 10:21 PM
FGride's Avatar
Default Re: (pucancakes)
i meant cant it be done if it can i bet i can so if i get the handle and the lock itself i can change it out
ekhatchey
Aug 27, 2009 04:51 PM
ekmushi_mushi
Dec 14, 2008 10:14 PM
JDMmadness
Aug 2, 2008 04:50 PM
Flar
14
Mar 15, 2006 10:29 AM
x916
19
Sep 10, 2002 11:24 PM
