{FS} 84mm B16 GE, Eagle, JE, CP, ITR, MOROSO, TONS OF DC STUFF, TONS OF B SERIES STUFF,
Old May 30, 2006 | 01:52 PM
J-Brooks's Avatar
Default {FS} 84mm B16 GE, Eagle, JE, CP, ITR, MOROSO, TONS OF DC STUFF, TONS OF B SERIES STUFF,
<FONT COLOR="RED">CLICK HERE FOR VOUCH THREAD</FONT>
<FONT COLOR="blue">FOR NOW. EVERYTHING IS OBO AND DOES NOT INCLUDE SHIPPING. FEEL FREE TO MAKE OFFERS. HOWEVER PLEASE DO NOT CLOG THIS THREAD WITH PRICE DISCREPANCIES OR ANYTHINGS SIMILAR. PLEASE JUST PM ME. ANYTHING RELATED TO WHAT IS SELLING PLEASE DO POST IN THE THREAD SO WHEN I ANSWER OTHERS WILL SEE. THANKS.</FONT>
<FONT COLOR="red">~ALREADY SOLD~</FONT>
ITR Crank. One journal needs polished. <FONT COLOR="red">SOLD</FONT>
GSR OBDI Distributor <FONT COLOR="red">SOLD</FONT>
B-Series Axles. No Clicking or anything. <FONT COLOR="red">SOLD</FONT>
DC Integra Powersteering pump, Lines, Reservoir and Mounts <FONT COLOR="red">SOLD </FONT>
GSR/ITR Water pump. Less than 4000 miles on it. <FONT COLOR="red">SOLD</FONT>
GSR Block. Perfect internals. OBD II Block. Headstud threads are messed up. <FONT COLOR="red">SOLD</FONT>
B-Series Tranny Torque Mount (Has energy suspension inserts) <FONT COLOR="red">SOLD</FONT>
Eagle Rods <FONT COLOR="red">SOLD</FONT>
Moroso Oil Pan with AN Fittings <FONT COLOR="red">SOLD </FONT>
Power Antennae. <FONT COLOR="red">SOLD </FONT>
CP Pistons (BRAND NEW) <FONT COLOR="red">SOLD </FONT>
GSR Block. One spun rod bearing. Not to bad. At most needs a new rod, bearing and machining of crank. A few hundred bucks worth of work at most. Block has about 115,XXX miles on it. <FONT COLOR="red">$300.00 </FONT>
84.5mm B16 Block. Has GE Godzilla sleeves in it now. Is on its way to have the new HD sleeves put in it. It will be bored to 84mm. <FONT COLOR="red"> Includes Freash GE HD SLEEVED Block, Headstuds, and Mains. Have other parts if interested.. PRICE = $1000.00</FONT>
Driver's Side door. Has a small flat spot around door handle. <FONT COLOR="red">$50.00</FONT>
GSR Head. Comes with valve cover, vtec solonoid, IM, throttle body, and distributor. Head has less than 2000 miles on everthing but the rockers. it has OMNI SS Valves, Ferrea Bronze Valve guides, Comp/Zex valvesprings and retainers, New OEM Valve seals, GSR Cams, Recieved a thorough cleaning, was milled flat, recieved a 3 angle valve job and was reassembled. <FONT COLOR="red">$850.00 as listed - - $700.00 w/o IM,TB, or Distributor</FONT>
GSR Intake Manifold with Throttle body. <FONT COLOR="red">$40.00</FONT>
OBDII GSR Harness (also picture below) MAP Sensor PLUG was ripped out so a new one has been soldered on. Other than that it is perfect. <FONT COLOR="red">$100.00</FONT>
GSR Intake Cam <FONT COLOR="red">$50.00</FONT>
Timing Covers (2 different sets and a couple of bottoms) <FONT COLOR="red">$25 for sets, $10 for bottom half</FONT>
B-Series Rear T-Bracket (Mount Bracket) <FONT COLOR="red">$35.00</FONT> PENDING
Uncut OBD I Vtec Harness <FONT COLOR="red">$125.00</FONT>
DC Integra Coolant Reservoir <FONT COLOR="red">$10.00</FONT>
B-Series Throttle Cable <FONT COLOR="red">$25.00</FONT>
Speed Sensor. Will work in B/D Series <FONT COLOR="red">$50.00</FONT>
B16 Crank. Perfectly Fine. <FONT COLOR="red">$125.00</FONT>
LS Crank. One journal needs polishing <FONT COLOR="red">$50.00</FONT>
H22 Throttle Body. Made to not have map sensor on TB. Perfect for those using 3/3.5/5 bar map sensors. <FONT COLOR="red">$60.00</FONT>
B-Series Crank Pullies (3) Come with whats pictured. All have keyways. <FONT COLOR="red">$30.00 each</FONT>
OBDI Wiring Harness. Has 3 Bar already wired in as well as a resistor box. Both will be included with harness. <FONT COLOR="red">$250.00</FONT>
DC Shifter <FONT COLOR="red">$10.00</FONT>
B-Series Alternators. 2nd one is almost brand new. <FONT COLOR="red">$50.00 for the first one, $75.00 for the second one</FONT>
B-Series Starters. Have 2. <FONT COLOR="red">$60.00 each **ONLY ONE LEFT NOW**</FONT>
DC Integra Fuel Filter <FONT COLOR="red">$5.00</FONT>
BOX-O-B-SERIES--Other random B-series parts for integras or b-series motors. <FONT COLOR="red">$50.00 or less</FONT>
JE Pistons. 3 Pistons are in really good shape. one is scuffed on the intake side I believe, other side is fine. Pistons are 84.5mm B-series. <FONT COLOR="red">$175 for the pistons</FONT>
B-Series Flywheel <FONT COLOR="red">$25.00</FONT>
Precision 600HP Intercooler. Mint Condition. Very nice piece. <FONT COLOR="red">$300.00</FONT>
H-Series Shifter Cables <FONT COLOR="red">$50.00</FONT>
OBDII H23 Distributor and JDM Throttle cable <FONT COLOR="red">$25.00</FONT>
H-Series Mounts. None are busted <FONT COLOR="red">$50.00</FONT>
H-Series Coil. Working condition. <FONT COLOR="red">$10.00</FONT>
B-Series Alternator Mounts <FONT COLOR="red">$10.00</FONT>
DC Integra Sylvania Silverstar Low Beams and Stock High Beams. Minimal usage on these. Motor blew not too long after putting them in. <FONT COLOR="red">$15.00</FONT>
Full DC Integra AC System. All Lines condenser etc. Will get better pictures upon request. But dont worry its all there. No leaks! <FONT COLOR="red">$150.00</FONT>
DC Integra Airbag <FONT COLOR="red">$15.00</FONT>
DC Integra Battery Tray <FONT COLOR="red">$10.00</FONT>
DC Integra Clutch Slave cylinder and complete clutch line all the way from the master cylinder. <FONT COLOR="red">$45.00</FONT>
DC Integra Rear Interior Panels. <FONT COLOR="red">$50.00</FONT>
DC Integra Rear Seatbelts <FONT COLOR="red">Seatbelts = $20.00</FONT>
Modified by J-Brooks at 1:13 AM 6/8/2006
Old May 30, 2006 | 09:43 PM
xyzalvarez's Avatar
pm .ed
Old May 31, 2006 | 07:56 AM
J-Brooks's Avatar
Default Re: {FS} 84mm B16 GE, Eagle, JE, CP, ITR, MOROSO, TONS OF DC STUFF, TONS OF B SERIES STUFF, (J-Brook
bump
Old May 31, 2006 | 08:02 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:07 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:12 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:17 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:21 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:22 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:28 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:33 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:38 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:43 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:48 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:53 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 08:58 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 09:04 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 09:09 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 09:15 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 09:20 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 09:25 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 09:30 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 09:36 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 09:41 AM
J-Brooks's Avatar
bump
Old May 31, 2006 | 09:44 AM
J-Brooks's Avatar
I don't know what the heck is wrong with my computer... it is automatically bumping my thread every 5 min.
