b18a1 vs b18b1 heads
Old May 30, 2006 | 01:40 PM
CivicVX94's Avatar
Default b18a1 vs b18b1 heads
how much better does a b1 head flow compared to an a1 head?
would an a1 with a p&p, deshrouded valves, and polishedd combustion chambers flow/perform better than a stock b1?
thanks for any help
Old May 30, 2006 | 04:59 PM
CivicVX94's Avatar
Default Re: b18a1 vs b18b1 heads (CivicVX94)
bump it up
someone knows this.....................
Old May 30, 2006 | 05:07 PM
lVlemphizStylez's Avatar
you should just get the b18b head...ive seen them sell for as little as 75 - 100 bucks here...much less than the work youre about to embark on
Old May 30, 2006 | 05:49 PM
ecks_fourttwo's Avatar
buy a b18b, new valve train and do the p&p and youll be very satisfied with the performance results.
Old May 30, 2006 | 06:44 PM
DC2 Mang's Avatar
they are the same ****, you can use either one for your build
Old May 30, 2006 | 06:58 PM
CivicVX94's Avatar
Default Re: b18a1 vs b18b1 heads (DC2 Mang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">you should just get the b18b head...ive seen them sell for as little as 75 - 100 bucks here...much less than the work youre about to embark on</TD></TR></TABLE>
well see i know someone selling an ls head with everything i said already done, but he lives a drive away and doesn't konw if it's an a1 or b1 head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">they are the same ****, you can use either one for your build</TD></TR></TABLE>
i thought i heard someone (but wanted to confirm) that b1's flow better than a1 heads?
Old May 30, 2006 | 10:39 PM
CivicVX94's Avatar
bump for the night
Old May 30, 2006 | 10:59 PM
b20powereDA's Avatar
same ****. cams are a lil different tho
Old May 30, 2006 | 11:16 PM
Leo C's Avatar
Night Owl
Default Re: b18a1 vs b18b1 heads (b20powereDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20powereDA &raquo;</TD></TR><TR><TD CLASS="quote">same ****. cams are a lil different tho</TD></TR></TABLE>
i thought the b18b's head was better flowing, hence the 10 hp increase over the previous gen
Old May 30, 2006 | 11:23 PM
IntegraLova's Avatar
Default Re: b18a1 vs b18b1 heads (shutupnskate)
The B18b intake cam is slightly more aggressive than the intake cam on a B18a.
Old May 31, 2006 | 12:35 AM
bks84's Avatar
Loved
well...
There are a few factors in why the generations make more power. Namely, the ECU, cams, exhuast manifold and intake manifold.
There's a **** load of debate, but nobody has any solid evidence. What I posted was hear-say as is 90% of hte posts in this thread.
I say get whichever [head] is cheaper, they all use hte same gaskets and ****.
Old May 31, 2006 | 05:20 AM
Danziver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">
i thought i heard someone (but wanted to confirm) that b1's flow better than a1 heads?</TD></TR></TABLE>
I heard this as well.
Old May 31, 2006 | 07:12 AM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutupnskate &raquo;</TD></TR><TR><TD CLASS="quote">
i thought the b18b's head was better flowing, hence the 10 hp increase over the previous gen</TD></TR></TABLE>
that has to do with the slight difference in cams, intake manifold, and ECU
the 92-93 integras saw a 10hp increase due to the cams and ECU change when honda switched over to obd1, the bare a1 heads are the same as the bare b1 heads
Old May 31, 2006 | 08:30 AM
CivicVX94's Avatar
the 92-93 integras saw a 10hp increase due to the cams and ECU change when honda switched over to obd1, the bare a1 heads are the same as the bare b1 heads</TD></TR></TABLE>
Great that's exactly waht i wanted to hear thanks a lot
it's going to be boosted with stage 3 cams and a skunk2 intake mani, no none of that stuff will matter.
Thanks for everyone's help
Old May 31, 2006 | 09:21 AM
whoa its len 2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote"> the bare a1 heads are the same as the bare b1 heads</TD></TR></TABLE>
I can vouch for that. My 93 b18a1 head is the same casting as my 94 b18b head. Same intake and exhaust port size.
Old May 31, 2006 | 09:36 AM
CivicVX94's Avatar
Default Re: b18a1 vs b18b1 heads (whoa its len 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoa its len 2 &raquo;</TD></TR><TR><TD CLASS="quote">
I can vouch for that. My 93 b18a1 head is the same casting as my 94 b18b head. Same intake and exhaust port size. </TD></TR></TABLE>
that's great, i'm very relieved to hear that
and i just want to make sure, a1 and b1 blocks are identical too right?
Old May 31, 2006 | 10:41 AM
Old May 31, 2006 | 11:44 AM
speedchoppy209's Avatar
b18B head are better
Old May 31, 2006 | 12:52 PM
Default Re: (TWISTED RACING)
what makes u think a b18b head is better? they are the same exact casting. there is a woppin 10 hp difference and that is due to im, header ecu, and cams. those are the only differences. but if ur building the head ur gonna swap cams right? ur gonna swap im right? ur gonna swap header right? and if u already got the a1 it jus seems more logical to sticck with the a1. flow characteristcs are the same on these heads same as a b20 head except for p8r. but if ur stuck on gettin a b18b head than ill sell u my b20 head which is the same ****. u get what im sayin? its all the same.
Old May 31, 2006 | 02:27 PM
bks84's Avatar
Loved
Default Re: (b20powereDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20powereDA &raquo;</TD></TR><TR><TD CLASS="quote">what makes u think a b18b head is better? they are the same exact casting. there is a woppin 10 hp difference and that is due to im, header ecu, and cams. those are the only differences. but if ur building the head ur gonna swap cams right? ur gonna swap im right? ur gonna swap header right? and if u already got the a1 it jus seems more logical to sticck with the a1. flow characteristcs are the same on these heads same as a b20 head except for p8r. but if ur stuck on gettin a b18b head than ill sell u my b20 head which is the same ****. u get what im sayin? its all the same. </TD></TR></TABLE>
couldnt have said it better, ******* trial users thinking they know what they are talking about.
Old Jun 4, 2006 | 07:34 PM
CivicVX94's Avatar
just thought i'd update...
i got the head it's a 98 p75 with a full port and polish, deshrouded valves, and polished combustion chambers.
the guy went to some performance cylinder head school and did it all himself.he said that this head was never flowed but he did the same work to a gsr head before and bench flowed it and the numbers were in the high 280's...so he does pretty good work and the head looks mint.
o ya i got it for 75 bucks
Old Jun 4, 2006 | 08:41 PM
Nors's Avatar
yeah I plan on doing a p&p on a head at school. Found a few heads, was wondering the difference myself, glad I found this thread. I am just going to get whatever is cheaper/closer.
Old Jun 4, 2006 | 09:22 PM
1337whp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">just thought i'd update...
nice dude, way t00 leet, keep us updated
Old Jun 5, 2006 | 06:08 PM
CivicVX94's Avatar
Default Re: b18a1 vs b18b1 heads (1337whp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337whp &raquo;</TD></TR><TR><TD CLASS="quote">
nice dude, way t00 leet, keep us updated </TD></TR></TABLE>
will do man...
i'll make a thread in the FI forum when my setup gets closer to completion...
fully built ls + gt35r
93CharcoalHatch
May 30, 2021 11:41 AM
thinkbrianthink
Mar 8, 2004 05:08 PM
R THIS
Dec 9, 2003 01:24 PM
BLUE EH3
Oct 29, 2003 09:51 PM
Charlie Moua
Jun 24, 2003 11:33 AM
