b20 i.m
will a jdm b20b i.m work for a swap, or do i have to get an ls one?
it will be going in my ek; also what kind of bracket will i need to keep my a/c?
thanks for any help.
that intake manifold is too tall, it will hit your hood unless you have a cowl hood. you will need an LS one......
as far as the a/c bracket, anything from an LS motor should work on the B20, since it is basically the same motor. only thing dif is the internals......
you can use the b20z IM, but not the b20b - other than that, yes the ls one works as well
And as for AC, you will need the pj7 from the crv, or the p54 from the del sol vtec - only those two will work
