OBD2a and OBD2b in HX?
Old May 30, 2006 | 12:31 PM
PhatBoy5015's Avatar
Default OBD2a and OBD2b in HX?
I know that 96-98 Civics are OBD2a and 99-00 are OBD2b. But someone told me that that isn't true for HXs. They said that all 96-00 HXs are OBD2a. Is this true? Because I need to buy a conversion harness for my 97 HX for an OBD1 B18B, and I want to make sure I get the right one. Thanks.
Old May 30, 2006 | 01:47 PM
hybridej7's Avatar
Default Re: OBD2a and OBD2b in HX? (PhatBoy5015)
all civics 96-98 are obd-2a, no matter, HX, EX, LX...w/e.....
all civics 99+ are obd-2b, not matter HX, EX, LX....w/e
i think the same goes for integras also......
im running the obd2a- obd1 harness in my car now and i know it came from an integra, i pulled it myself.......
Old May 31, 2006 | 08:36 AM
OK thanks. Can I get a second opinion just to be sure? Bump
Old May 31, 2006 | 09:15 AM
EE_Chris's Avatar
I asked this question many years ago and for someone to check their 99-00 Hx ECU for the connector configuration - but I never got a reply.
So yes, according to the Helms ETM, the Hx from 96-99 (I'll assume 00 too, but the ETM I have only covers up to 99) was OBD2a. When you look at the top of the page for the description, you're greeted with "All 96-98 models except D16B5; 99 D16Y5 with M/T".
The Hx was def OBD2a between 96-98 so don't worry about your 97 being something else. If you had a 99-00, I'd say go out and check your ECU connector configuration to be sure of what conversion harness to order.
Old May 31, 2006 | 09:21 AM
Default Re: OBD2a and OBD2b in HX? (EE_Chris)
Ok thanks guys.
Arthas
May 19, 2009 02:26 PM
imzjustplayin
19
Jun 5, 2008 08:54 AM
Basically
Dec 7, 2005 05:45 AM
Timmay
33
Oct 19, 2005 08:50 AM
eg686
May 25, 2004 09:35 AM
