Head gasket job Q's
Old May 30, 2006 | 12:28 PM
purangboy's Avatar
Default Head gasket job Q's
I am in the works of doing a head gasket job on b18b1, the manual says for removing the head to take off the intake manifold, timeing, and alot of other stuff, I pulled the valve cover last night, if I remove the cams I can get to the head bolts, after pulling those, wont I be able to just rip the head off? Will i have to remove the valves? Also, I am not sure If I warped my head when I heated it up, but water leaks out between the block and the head, on the passanger side of the engine I see no traces of water in the oil even after I pulled the valve cover off and the compression seems fine when I start. thanks
Old May 30, 2006 | 12:33 PM
Lan's Avatar
Lan
Default Re: Head gasket job Q's (purangboy)
You won't have to take the valves out to pull the head. Sounds like you need a new headgasket to me.
yblegal
Dec 1, 2010 09:53 AM
98exowner
10
Oct 12, 2008 10:03 PM
integraman 95
Dec 4, 2007 04:30 AM
realis9
Jun 28, 2006 07:27 AM
domestic_rice
Sep 25, 2005 12:49 PM
