no vtec after manifold install
Old May 30, 2006 | 10:22 AM
slowcrxsib16's Avatar
Default no vtec after manifold install
i installed a preofessional products intake manifold, hci did an install on a itr a few months back and they loved it, so i got one, i also put a 65mm Tb on in, anyhow, i have a few vacuum leaks, but other than that, its not bad, other than the fact that i lost vtec, its on a b16, and vtec is non existant. I dont know what the hell is going on, its like i have a ls with out the torque, i took it to a friends house who put the swap in and he is trying to figure it out, i dont know what it could be, if you know what it could be, lemme know yo, help a brotha out
Old May 30, 2006 | 10:50 AM
crx_88_si's Avatar
did they put all the normal hoses and sensors back, namely the intake air temp sensor.
Old May 30, 2006 | 10:55 AM
Default Re: (crx_88_si)
yeah, i think the map sensor is the only one not hooked up, the temp sensor on the front side of the intake is installed though, but when i say we have vacuum leaks, i mean.... some hoses are hooked up to... nothing. will those sensors prevent vtec from engaging?? we are working on it this evening so hopefully we will get those hooked up right tonight
Old May 30, 2006 | 11:26 AM
Redline130's Avatar
Default Re: (slowcrxsib16)
First off, you will need to have the MAP sensor plugged in. Are there any other sensors not plugged in? Is the VTEC pressure switch and solenoid plugged in? Why didn't you reinstall everything back to how it should be? (vacuum hoses).
Old May 31, 2006 | 08:25 AM
Default Re: (Redline130)
well, my dumb *** had some "friends" help, and while they were taking the old manifold apart, and disconnecting the hoses, i was putting the new tb on the new manifold. Of course it started to rain so we were gonna do it the next day, but seemed like non of them wanted to come out and help, and since i let them uinstall the manifold, i didnt know how the hoses went on. I have the car at another friends house, the guy that actually put the motor in for me, so he should know how they plug up, but he doesnt know why vtec isnt working. I checked the vtec seleniod, and i checked all the injectors make sure they are hooked up. We are working on it still, but we figured while it was down we would through my cams in it and just reinstall it while we trial and error on the hoses. But with the hoses and that sensor off, will that cause vtec not to work b/c i always thought vtec worked off oil pressure??
Old May 31, 2006 | 08:47 AM
Loserkidwac's Avatar
Duh, you removed the vtec intake mani and probably got a non-vetech one by accident seen it happy a million times
Old May 31, 2006 | 08:48 AM
Suck my DX's Avatar
thats sad
Old May 31, 2006 | 09:31 AM
Default Re: (Suck my DX)
they look the same, i mean physically, the company said that it would fit b16, b17 and type r's. How can you tell if it is a non vtec intake manifold? The company doesnt make a manifold for non vtec motors
http://www.tornactive.com/pd_p...s.cfm
go to this site, the is the exact one, but not polished mine is satin. Like i said the company doesnt make an ls intake, so it cant be a non vtec intake.
Old May 31, 2006 | 09:45 AM
Autoworks's Avatar
Default Re: (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">Duh, you removed the vtec intake mani and probably got a non-vetech one by accident seen it happy a million times </TD></TR></TABLE>
that's impossible in this case
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcrxsib16 &raquo;</TD></TR><TR><TD CLASS="quote"> The company doesnt make a manifold for non vtec motors
correct
With the AEBS you will have extra vacuum ports that need to be capped off. Yo umust reconnect the sensors. If you have a leak you should have an irratic idle to go along with it.
Old May 31, 2006 | 09:51 AM
Default Re: (Autoworks)
oh yeah its got a real messed up idle, **** sounds like a small block chevy camming. I have all the nipples on the back blocked off. should these sensors cause vtec to screw up?? I mean we have to relocate the sensor on the firewall and put it on the throttle body which shouldnt be hard, but should this fix my problem?
Old May 31, 2006 | 09:53 AM
Autoworks's Avatar
I wouldn't worry about VTEC until you get the mani installed properly first. Find the leaks first.
Old May 31, 2006 | 09:57 AM
yellowrexsi's Avatar
We just had a similar problem with a h22 hatch. The vtec quit working when the map sensor crapped out on us.
Do like everyone said and fix the original problems first, then go back through and make sure all your sensors are hooked up.
Old May 31, 2006 | 10:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
It was a joke
Old May 31, 2006 | 10:46 AM
STREETWERKZ's Avatar
sad that he might have got a non vtec manifold.
hook the map sensor up dude.... if you have any cel, your vtec wont engage.
Old May 31, 2006 | 12:48 PM
Default Re: (STREETWERKZ)
cool cool, im going ovedr that guys house after i get out of school this evening. ill let yall know how it goes, thanks for the help.
STREETWERKS, dont you know hwo i am? lol im the juggernaut bitch! have you seen the xmen parody that some guys did? look on yahoo and type in juggernaut bitch, but thanks again guys
Old May 31, 2006 | 12:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcrxsib16 &raquo;</TD></TR><TR><TD CLASS="quote">STREETWERKS, dont you know hwo i am? lol im the juggernaut bitch! have you seen the xmen parody that some guys did? </TD></TR></TABLE>
no clue what you are talking about.
Old May 31, 2006 | 01:01 PM
i saw your pic thing on the left and made me think of this short vid online.
http://www.crossroadvideos.com...1.htm
theres the link to it, its funny as hell. Plus i wanna get some streetwerks shirts here in a little bit
Old May 31, 2006 | 01:06 PM
Plus i wanna get some streetwerks shirts here in a little bit</TD></TR></TABLE>
if thats the case...... i'm glad you like my video.
http://profile.myspace.com/ind...40828
but buy the shirts first.
http://www.STREETWERKZclothing.com
Emir Taljanovic
Sep 11, 2017 10:14 PM
city2citydc4
Apr 2, 2015 01:15 PM
chinewalker
Oct 1, 2009 04:25 PM
adolfovalen
Engine Management and Tuning
Apr 19, 2008 01:42 PM
clos0821
Sep 7, 2004 04:48 PM
