When i use my turn signal the tach, speedometer, and the rest of the gauges turn off.
Old May 30, 2006 | 10:15 AM
verycleanhatch's Avatar
Default When i use my turn signal the tach, speedometer, and the rest of the gauges turn off.
The turn signal lights turn stops working too. The backlight for the cluster works stays on though. What could be the problem?
When i start my car my gauges do not work until i move my car also.
Modified by verycleanhatch at 11:26 AM 5/30/2006
Old May 30, 2006 | 12:23 PM
slodel's Avatar
Default Re: When i use my turn signal the tach, speedometer, and the rest of the gauges turn off. (veryclean
sounds like a problem
Old May 30, 2006 | 01:27 PM
yongster22's Avatar
wow my guess is that you have a short when did it start happining, what did you install (if you installed anything) and go from there.
Old May 30, 2006 | 01:37 PM
Ser1N's Avatar
Default Re: (yongster22)
could it maybe be a ground?
Old May 30, 2006 | 01:49 PM
cambopheonix56's Avatar
Default Re: (Ser1N)
Short or a grounding problem. Thats about all we can do for you.
KyleVA
Jun 24, 2011 03:55 PM
Augustin
Jul 2, 2007 04:51 PM
Tatakai
Feb 6, 2006 08:17 PM
InMyProject
Mar 16, 2005 07:49 AM
sparq
Mar 29, 2003 02:38 PM
