Antenna Doesn't go Down...
Old May 30, 2006 | 09:46 AM
pizzle's Avatar
Default Antenna Doesn't go Down...
On my 99 Integra... the antenna doesnt go down...it is stuck in the up position. You can hear the motor running...and some clicking. I've heard I need to replace the mast...but just wanted to see what you guys have to say. Is there any way I can get it to go down until I can get the new parts?
Old May 30, 2006 | 09:55 AM
trick_db's Avatar
Default Re: Antenna Doesn't go Down... (pizzle)
ey when you do the jdm front end conversion , you will need Da cable and latch. let me noe when you getting the front end. btw you still have your 98 headlight?
Old May 30, 2006 | 09:58 AM
pizzle's Avatar
Default Re: Antenna Doesn't go Down... (trick_db)
yes...still have the headlights.... I'll let you know...
Old May 30, 2006 | 10:00 AM
trick_db's Avatar
everything still works fine? let me noe wassup.
Old May 30, 2006 | 10:04 AM
pizzle's Avatar
yeah... I need this damn antenna to go down
Old May 30, 2006 | 10:19 AM
trick_db's Avatar
try to take it out and take a look at it. or spray it with wd40..ask typerman2001 buy a replacement 1. hope that will work
Old May 30, 2006 | 11:02 AM
02 accord's Avatar
Did you try to manually push it down?
Old May 30, 2006 | 11:16 AM
95IntegraGSRAZ's Avatar
Default Re: Antenna Doesn't go Down... (02 accord)
Mines the same... wont go down, clicks and runs but wont go down, and you cant push it down.
Old May 30, 2006 | 11:25 AM
pizzle's Avatar
Default Re: Antenna Doesn't go Down... (95IntegraGSRAZ)
Yeah.... I can't push mine either...
Old May 30, 2006 | 11:29 AM
acuratuner00's Avatar
I had the same problem...I had to force it down with a book. It bent a little but I didnt care too much. I went for the S2000 Antenna.
Cheaper and better IMO.
Old May 30, 2006 | 11:39 AM
beardDc2's Avatar
yeah mine too pretty jank if you ask me... i jambed mine down till it wouldn't come back up. then it was a-ok.
Old May 30, 2006 | 11:47 AM
pizzle's Avatar
Default Re: Antenna Doesn't go Down... (acuratuner00)
How much was your S2K antenna?
lancerkid06
Feb 27, 2010 08:56 PM
Jdmls
Jul 14, 2007 08:27 PM
ajchen
Apr 10, 2003 12:23 PM
Ben-VTEC
Feb 28, 2003 10:55 PM
TypeRod
Nov 29, 2002 08:45 AM
