fidanza flywheel question
Old May 30, 2006 | 09:17 AM
Tmagic's Avatar
Default fidanza flywheel question
i found a good price for a fidanza flywheel about $147 for one. but im hesitating in buying one because the fidanza is 7.5lbs...is that too light? its for daily driving also.......if anyone have any experience on this flywheel, i would like some opinions...thanks
Old May 30, 2006 | 09:19 AM
lVlemphizStylez's Avatar
Default Re: fidanza flywheel question (JICmagic)
buy the flywheel and be done with it...ppl talk garbage about the flywheels making car harder to drive...adding turbo lag....all sorts of bs...
my only suggestion is use chromoly steel...
Old May 30, 2006 | 10:10 AM
Tmagic's Avatar
Default Re: fidanza flywheel question (lVlemphizStylez)
cool thanks.....anyone else used fidanza flyweel
Old May 30, 2006 | 10:36 AM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
I would never worry about having a flywheel too light... everyone thats in my car club has had positive results from them.
Only suggestion is to buy one that is strong enough to handle the stress.... my buddies are runnin ACT but fidanza has a good reputation too. Id buy it, if you dont.
Old May 30, 2006 | 10:58 AM
85mm LS VTEC's Avatar
That's a good price. I have one in my race hatch and it works great. I'd buy it if I were you.
Old May 30, 2006 | 11:48 AM
skunked's Avatar
Default Re: fidanza flywheel question (85mm LS VTEC)
I run a Fidanza, they work great
Old May 30, 2006 | 02:12 PM
Tmagic's Avatar
thanks for the help guys.......im picking up the flywheel today
Old May 30, 2006 | 04:07 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Have one also, but not installed yet. I'm sure I'll like it.
Old May 30, 2006 | 04:47 PM
Danziver's Avatar
Default Re: fidanza flywheel question (00IntegrAllmotoR)
I have a 7.5 and i like it.
Old May 30, 2006 | 05:14 PM
VtecAdvantage's Avatar
i JUST finished my break-in period with my new Exedy stage 1 clutch and fidanza flywheel. When i got to test it out for the first time i was amazed. The response and quick revs are the main advantages.
But i learned 1st hand that the rumors about lightweight flywheels are BS. I stalled my car twice after the new clutch (the day i put it in) and i haven't stalled it since. You don't have to rev the **** out of the motor, and your car won't be too hard to drive.
And, as for the other rumor, I've herd from turbo guys that lightweight flywheels help with turbo lag not add to it.
My personal experience - Fidanza lightweight flywheel
Just make sure you follow all directions carefully, make sure everythings torqued right and break in ur clutch properly if you get a new one.
Old May 30, 2006 | 06:07 PM
ejmatzell's Avatar
Default Re: fidanza flywheel question (VtecAdvantage)
not to ruin your thread..... but what are peoples opinions on an exedy clutch and flywheel combination?
whitehf
Feb 4, 2006 05:20 AM
Rickcrx
Jun 28, 2004 03:18 PM
Xecutive
Apr 20, 2004 05:33 AM
(__________)
Dec 1, 2002 06:53 PM
jonnyc
Jan 30, 2002 12:11 PM
