Transmission problem need Help...!!!
Old May 30, 2006 | 09:02 AM
EJK20R's Avatar
Default Transmission problem need Help...!!!
ok I have a 99 civic Si and sometimes when I crank the engine and press down on the clutch pedal the car will not shift into reverse or any gears. I recently changed my clutch master and checked if my slave was leaking no leaks.... I am thinking can it be internal ....?
Old Jun 2, 2006 | 12:02 AM
MY EJ6's Avatar
Default Re: Transmission problem need Help...!!! (EJK20R)
im not sure what that is but i just changed my axels and now im having problems with my tranny or clutch in higher rpms i can push the clutch and nothing happens its like i just took my foot off the gas its also hard to put in gear and the car is also shaking alot il let you know if i find out any of your problems
Old Jun 2, 2006 | 04:36 AM
Honda Bull's Avatar
Wow... you guys have some problems. Usually stuff like this doesn't just happen overnight. Was it gradual or just happen when you woke up one morning?
Old Jun 2, 2006 | 04:50 AM
MY EJ6's Avatar
Default Re: Transmission problem need Help...!!! (Honda Bull)
mine did never had a problem changed axels cause cvboots were ripped went to test drive it and it got *** up
Old Jun 2, 2006 | 08:16 AM
trickeng's Avatar
Default Re: Transmission problem need Help...!!! (97 SIR dx)
your clutch is most likely broken or it has thrown a spring....
was it making noises before this happened?
Alope
Feb 25, 2014 07:29 PM
islandhonda
Jun 1, 2007 09:02 AM
hatchsi0485
Nov 21, 2005 06:13 AM
dtrtw
Jun 5, 2005 08:02 PM
D-Rob
Mar 7, 2005 12:16 PM
