00' b16a2 swap on 96 civic bogging when cold
I have a b16a2 swapped in my EK, I'm running a jumper harness OBD2a-obd1 w/ a p30 ecu.
When I first start up my engine, it idle's fine and everything, but if i drive it in first gear, sometimes I feel like the motor is bogging, but its fine after my temp is warm.
What could be the problem? fuel, distributor, timing?
ttt.
btw, when i try hammering it on 1st gear, it kinda hesitates a bit then i let go off the gas and hammer it again and seems to hesitate again and then picks up after about 3k.
same thing happend to me and I was told it had something to do with the fuel filter. Since mine came with an AEM fuel filter it was doing the same thing as yours so I took it out and reinstalled it myself and now its perfectly fine I assumed the guy before me didnt install it correctly. So you might want to check out your fuel filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivicb16 »</TD></TR><TR><TD CLASS="quote">same thing happens to me, i guess its normal so i hear</TD></TR></TABLE>
I had 200 b16a2 swaped into my eg and it ran perfet when cold so no its not normal. or shouldnt be
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">You all do know VTEC does not engauge when its cold? So you would bog major at a high rpm (above 5500)</TD></TR></TABLE>
yea, But it seems to me he is talking about when he tries to take off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyboy204 »</TD></TR><TR><TD CLASS="quote">who said anything about vtec engagement? :S</TD></TR></TABLE>
Lol i dont know...
Lol i dont know...
chankyeyes
May 17, 2003 01:10 AM
