will dohc ecu run a sohc?
yes, it may throw a code due to the lack of knock-sensor. I ran a mugen ecu for dohc for like 3 months on my 94 ex. obd 2/ obd 1 is and issue, what year car and ecu?
duh i looked at your sig, make sure the ecu is 96 or 97.
[Modified by Plan B, 12:21 PM 4/14/2002]
i made myself an obdI conversion harness and to see if it worked i was going to use a friends obdI del sol vtec ecu to see if it worked with no codes instead of buying a p28. until i know that it works i wont buy one. but if it will throw a code anyway then there is no point in me using the dohc.
Just have somebody with a 92-95 civic ex come over and let you borrow his ecu for a few minutes to see if it works, 4 10mm bolts and 3 plugs and you'll find out if you saved yourself $250 or not.
yea i made mine for only $50. i dont know anyone with any 5th gen ex or si thats not already swapped. thats why i wanted to know whether the dohc one would work.
just to let everybody know, it worked. i let him use my p30 ECU. d16y8 revving to 8k was pretty fun. i wouldn't recommend that anybody rev their single cam to 8k on the regular or anything, but it was pretty cool to do like twice.
yep it worked for only $50! now i just need to get a stock p28 for it, so i can use the harness. it was fun to rev my car to 8k for the first and probably only time in its life.
the soL that could
Mar 21, 2006 02:21 PM
jonnybravo
Feb 21, 2002 09:05 PM
