Brake safety issue.... Check your damn lines!
Old May 29, 2006 | 08:19 PM
tommytoes's Avatar
Default Brake safety issue.... Check your damn lines!
Ok, I've got a brake fluid "leak" and I will use that word very loosely since it's not a steady leak but mostly moisture forming at the metal connections and while it has started to lower my fluid level it has not "yet" affected my braking. Not that I can tell anyway.
Well here's the bike; an 05 SV650 with 9000+ miles, regularly scheduled and kept outside in the hot *** AZ desert weather.
Here you can see the brake fluid seeping at the underside of the lower crimp.
The top of the top crimp
And another shot from the back side with the sleeve pulled up.
Now I've already ordered a Goodridge stainless steel brakeline kit which should be here next week and was only 7 bucks more than the stock line assembly.
Just wanted to remind you guys.... Especially those of you that don't do your own maintenance, to give your bike a good once over at LEAST once a month from top to bottom. I'm glad I caught this before I caught the back of a semi.
SV owners feel free to chime in on their brake experiences.
Peace.
Old May 29, 2006 | 08:21 PM
sup gurl's Avatar
Wow good thing you noticed that...gonna check mine a LOT more often now
`05 SV with 9k miles...you ride a lot
Awesome bike by the way
Old May 29, 2006 | 08:33 PM
tommytoes's Avatar
Default Re: (sup gurl)
The bike had it's first birthday with me last monthand yes I put many miles on it, 40 miles every Monday through Friday and usually 60-100 miles on Saturdays Junkyard hopping. It's been nothing but realiable to me and I want to blame this on a singular manufacturing defect cause all other owners in my area have had no such probs.
Old May 29, 2006 | 10:28 PM
Kusai.Nihonjin.Desu's Avatar
Default Re: (tommytoes)
Warranty?
Old May 30, 2006 | 02:26 AM
god.loves.ugly
Guest
Posts: n/a
Good looking bike I just scooped one like it up, I will be sure to check my lines I was going to hook up some SS braided ones eventually anyway.
Old May 30, 2006 | 06:31 AM
MSchu's Avatar
My Name is Nobody
Default Re: (God.Loves.Ugly)
You should ALWAYS do a walk around before getting on... every time you ride. I usually do a quick visual inspection of the brakes and related areas, the hardware fixing the wheels to the bike, the chain area and the steering/head tube. this takes about 30 seconds to accomplish. ever seen a pilot take off without doing a walk around?
Old May 30, 2006 | 07:45 PM
tommytoes's Avatar
Default Re: (MSchu)
Well as far as warranty goes, it expired the 30th of last month and I thought that Suzuki would be interested as it might be a defect issue of even something to just document for reporting even if not under warranty. But no, I called 3 Suki dealers and they all wanted 75 dollars just to look at it and tell me I need a new line.
So pay 75 dollars to have someone tell me something I already know or pay 89 to get a new ss line......it's a no brainer.
And MSchu you are absolutely right about doing a walk around everytime but I have been guilty of only doing a quick tire/chain/brake pad check. Well needless to say that's the end of that.
Old May 31, 2006 | 06:35 AM
MSchu's Avatar
My Name is Nobody
Good for you, I love to see responsible riding techniques, specially form young folks.... as opposed to "Hey, I just mounted my own tires, it's fun and easy, and I am not even going to get them balanced" posts... not to smart.
this is what I am doing daily:
thanks... you should look for leaks for any kind that may effect your bikes ability to run without problems, not small valve cover leaks but a brake line leak may indeed result in complete failure. I look at all bolts that attach the wheels to the bike, axle bolts and the locking bolts that keep the axles fixed to the bike, I look at the chain area to see if it is abnormally loose or tight, this can also result in a failure at speed or may just be an indication that something is wrong with the alignment and or locking bolts of the rear of your bike. I also do a steering/head tube bearing check by turning the handle bars full left and full right, when in the full position left or right lock the front brakes and rock the bike forward and backward in rapid succession, this will give you a general indication if the head tube bearings are loose/maladjusted. If you have been having trouble with your pegs or brake/shifting mechanism, keep that on your list to inspect every ride also. sufficient air in tires and debris in tread is also very important. This entire walk around take less than 20-30 seconds and your on your way! thanks for asking
Old May 31, 2006 | 12:11 PM
tommytoes's Avatar
Default Re: (MSchu)
Good info and thanks and it's good to be grouped into the "young folks" at 26 going on 27 being called young is quite an ego booster. Thanks you old fart (just messin)
And my Brakelines come in thursday so I think I may do a writeup on it with lots of pics
Old May 31, 2006 | 01:05 PM
MSchu's Avatar
My Name is Nobody
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommytoes &raquo;</TD></TR><TR><TD CLASS="quote">Good info and thanks and it's good to be grouped into the "young folks" at 26 going on 27 being called young is quite an ego booster.</TD></TR></TABLE>
Damn, I have been riding the street for as long as you have been alive... I bought my first new street bike in 79/80
Old May 31, 2006 | 07:28 PM
tommytoes's Avatar
Default Re: (MSchu)
And suddenly 26 feels very young again .
Kinda puts my one year of riding into perspective. Damn I'm a newb!!!
Well looks like I've got plenty of learning to do.
Old May 31, 2006 | 07:50 PM
sup gurl's Avatar
Default Re: (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote"> I bought my first new street bike in 79/80</TD></TR></TABLE>
Wow my parents were barely out of high school then, hahah...and little did they know 7 years later I would be in existence
Old May 31, 2006 | 10:25 PM
CRXDrew's Avatar
Default Re: (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">Good for you, I love to see responsible riding techniques, specially form young folks.... as opposed to "Hey, I just mounted my own tires, it's fun and easy, and I am not even going to get them balanced" posts... not to smart.
Yea that was me... that shot wasn't really necessary though.
Old May 31, 2006 | 10:55 PM
rjay8604's Avatar
Default Re: (CRXDrew)
I'm glad you made this post, especially since you have an SV as well. I checked my 02 SV, all my lines were golden fortunately.
Old Jun 1, 2006 | 09:40 AM
MSchu's Avatar
My Name is Nobody
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">
Yea that was me... that shot wasn't really necessary though. </TD></TR></TABLE>
Then I retract it and apologize, sorry about that
Old Jun 1, 2006 | 09:44 AM
evil vapor's Avatar
Default Re: (rjay8604)
2 weeks ago I noticed my clutch line on my RC51 sweating brake fluid just like yours, maybe a little more pronounced. Been lazy to take it to the dealer, it's only 9 months old and still under warranty.
Old Jun 1, 2006 | 12:29 PM
tommytoes's Avatar
Default Re: (evil vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">2 weeks ago I noticed my clutch line on my RC51 sweating brake fluid just like yours, maybe a little more pronounced. Been lazy to take it to the dealer, it's only 9 months old and still under warranty. </TD></TR></TABLE>
You better take it in then, nothing was wrong with mine till after the warranty was up....Kinda like the bike knew hmmmm
strider2
Honda CR-V & Element
May 11, 2018 11:51 AM
Team Bukkake Sucks!!!
11
Dec 13, 2006 09:27 AM
david
Oct 31, 2005 11:02 AM
Cuong-nutz
May 11, 2005 03:54 PM
TheOne
Jul 20, 2003 03:28 PM
