How to test Main relay for a 92 civic??
Old Apr 14, 2002 | 07:45 AM
Petah's Avatar
Default How to test Main relay for a 92 civic??
Last season, i had a few occasions where my car wouldn't start but would start up if i turned the key completely off and cranking it again.. Today, i finally changed the main relay out cause people were telling me that was cause to my problems. But is there a way to test my old one so i can be sure that was the cause to my problem?
Old Apr 14, 2002 | 07:51 AM
mantic6t9's Avatar
Default Re: How to test Main relay for a 92 civic?? (eg-six)
It's kinda hard to test because it doesn't happen all the time. I had the same problem with my 93 si hb, i noticed you wouldn't hear any clicks or the fuel pump priming the injectors when you turn the key. You may be able to take it apart and look for cracks in the solder i never bothererd. After i replaced mine the problem went away that's all i cared about.
Old Apr 14, 2002 | 07:52 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Look at the soldering points on the inside of the relay. Even the most tiny cracks can cause failure.
If you happen to see a cracked soldering point, re-solder ot and keep that relay as a spare. You can actually repair them! I would keep ut as a back-up only, because if it cracked in one place, it will crack sooner in others too.
Old Apr 14, 2002 | 08:01 AM
Plan B's Avatar
Default Re: How to test Main relay for a 92 civic?? (B18C5-EH2)
When mine would mess up, i could turn the key, and it wouldn't start, then i'd just tap the relay, and kazaam, start up!
Old Apr 14, 2002 | 08:06 AM
mantic6t9's Avatar
Default Re: How to test Main relay for a 92 civic?? (Plan B)
$47 from honda to have you car start first try every time is worth it.
Old Apr 14, 2002 | 08:07 AM
Plan B's Avatar
Default Re: How to test Main relay for a 92 civic?? (mantic6t9)
tell them you work for advance auto parts or something next time, then they'll give it to you for $37. Also napa makes on that's a little cheaper, works the same.
Old Apr 14, 2002 | 08:21 AM
Petah's Avatar
Thanks for the advice....so i take it that this is a very common problem with hondas........but can you take those things apart to resolder the cracked points? It looks like the unit is sealed.......
wood
Oct 8, 2009 02:36 PM
nafreak
Jun 15, 2003 12:37 PM
