Quaife LSD.... what fluid???
Old May 29, 2006 | 06:48 PM
enigma94's Avatar
Default Quaife LSD.... what fluid???
I have a GSR with a b16 tranny with a quaife LSD and it seems its becoming increasingly harder and harder to get into gear. I have a ITR shifer and a act street strip clutch.
I change out the tranny fluid every oil change with OEM honda MTF because that is what i believed was the correct fuild to use. Now that this problem has started occuring I just wanted to double check that it is the correct fuild to use.
Second, could i possibly use some GM syncromesh/MTF mix to help smoothen up the shifting? Ive used it in the past with no problems i just wanted to make sure it wouldnt damage the LSD before i go dumping it in there....
TIA!
Old May 29, 2006 | 07:16 PM
Yell88CRXsi's Avatar
Default Re: Quaife LSD.... what fluid??? (enigma94)
I've used nothing but Honda MTF in my Quaife YS1 for over 4 years with no problems.
I've never had to use it, but GM syncromesh will work with a quaife tranny. It's the clutch/plate style LSD's that require diffrent fluid.
Old May 29, 2006 | 11:40 PM
rodimus's Avatar
if you get gm syncromesh, make sure it's the FRICTION MODIFIED version..costs a little more, but that's the one you want.
Old May 30, 2006 | 03:50 PM
enigma94's Avatar
Default Re: Quaife LSD.... what fluid??? (EVOL)
ok thanks guys!!
Old Jul 11, 2006 | 11:39 AM
wenlyone's Avatar
no. you don't want friction modified, it will f up your synchro
Old Jul 11, 2006 | 01:31 PM
enigma94's Avatar
Default Re: Quaife LSD.... what fluid??? (wenlyone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wenlyone &raquo;</TD></TR><TR><TD CLASS="quote">no. you don't want friction modified, it will f up your synchro
Old Jul 11, 2006 | 02:10 PM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wenlyone &raquo;</TD></TR><TR><TD CLASS="quote">no. you don't want friction modified, it will f up your synchro</TD></TR></TABLE>
friction modified fluid is supposed to promote smoother shifting. Please explain your statement.
oramac_eg
Oct 5, 2008 01:57 PM
SFWDcoupe
May 19, 2006 11:06 AM
j87w
Jan 12, 2005 12:36 AM
JDMCRX
Jun 5, 2004 08:46 PM
crx(gator)
Jan 13, 2002 03:25 PM
