cut wires ... help! in a DC teg.
Old May 29, 2006 | 06:27 PM
.Thomas's Avatar
Default cut wires ... help! in a DC teg.
I just recentley purchased an integra, and for the stero, i got a bunch of cut wires. this was because he had an older headunit that he wanted, and when he installed it, did not use the adapter. is there any way where i can buy an aftermarket HU, and the adapter, and just cut off the "stock" side and then just crimp the wires together accordlingly? or is there another way?
thanks
Old May 29, 2006 | 06:54 PM
02 accord's Avatar
Default Re: cut wires ... help! in a DC teg. (TanDC4)
Yes, you can just connect the wires from the headunit right into the wires in the car. You shouldn't need an adapter. http://www.installdr.com/Harnesses/HA-Wiring.pdf should help you figuring out which wires are for what. If you decide to put the stock connector on there just so you can buy an aftermarket one to plug into it (waste of money if you're not going to change headunits often), then http://www.metraonline.com/ should have what you're looking for.
Old May 29, 2006 | 06:57 PM
.Thomas's Avatar
Default Re: cut wires ... help! in a DC teg. (02 accord)
thanks, should i get a multimeter?
Old May 29, 2006 | 07:03 PM
02 accord's Avatar
If you're going to be doing a lot of electrical work on the car, then it would be a good idea to get one. But just for installing a head unit, one isn't necessary.
Old May 31, 2006 | 07:31 PM
siggy833's Avatar
Uh I would invest in a multi-meter just to be safe, especially if you've never done that kinda thing before. Just my 2cents.
Old May 31, 2006 | 07:52 PM
Leo C's Avatar
Night Owl
Default Re: cut wires ... help! in a DC teg. (TanCar)
just get some wire nuts and wire it up yourself man that's the only way to do it if the wires have been cut.
here jus cause i'm a nice guy
red/grn= fron pass. speaker +
blu/grn = drvr door spkr +
red/blk= lights on signal
wht/blu= constant power (tuning memory)
yel/red= acc ( main stereo power supply)
yel/grn= radio switched power (to antenna)
blu/yel= left rear speaker +
red/yel= right rear speaker +
brn/blk= front pass. speaker -
gry/blk= drvr door. speaker -
blk= ground
gry/wht= left rear speaker -
brn/wht= right rear speaker-
Old May 31, 2006 | 08:34 PM
.Thomas's Avatar
Default Re: cut wires ... help! in a DC teg. (shutupnskate)
thanks, will the instructions with the deck show me where to wire what?
Old May 31, 2006 | 08:41 PM
Leo C's Avatar
Night Owl
usually the instructions will tell u which wires go to what or the wires themselves should be labeled with (ground, power supply, antenna, left rear, etc.)
if they aren;t post em up and i will tell u what to wire to what
Old May 31, 2006 | 09:12 PM
.Thomas's Avatar
thanks for all the help
Old Jun 1, 2006 | 01:44 PM
8520's Avatar
I had the same problem when I bought my car. Damn car thieves.
I simply ended up wiring on a new male harness in the factory spot. Easy and can save yourself a lot of work in the future
Bestkits model numbers BHA1720 & BHO1720
Old Jun 1, 2006 | 04:09 PM
.Thomas's Avatar
Default Re: cut wires ... help! in a DC teg. (a_s_ol_)
where do you buy the kits?
Old Jun 1, 2006 | 04:44 PM
8520's Avatar
Not so much a kit, rather two harnesses. Any local car audio place will have them. Don't pay more than about 8 bucks a piece, even though most places will want 15+ for them
hennessy
Audio / Security / Video
May 4, 2006 01:51 PM
gray_civic_coupe
Jan 9, 2006 10:51 PM
HaUTSaauce
Jan 10, 2002 02:41 PM
SOHCmycord
Sep 10, 2001 06:10 PM
