Learning TIG + aluminum
Old May 29, 2006 | 04:46 PM
WhiteSol's Avatar
Default Learning TIG + aluminum
Hi all,
Just looking for some input on my TIG welds.. I've been welding with TIG for all of about 2 hours and I decided to try aluminum. I would like some input on what could help make them better beyond the obvious. I'm most concerned with proper weld cleaning at this point, and was considering lowering the AC waveshape balance (factory setting of 75, down to 65?) to increase the weld cleaning effect. I got the best looking penetration on the final weld #8 (looked very similar to the top side). I'll post a pic of that later if need be..
Setup is Dynasty 200DX, pure argon (20cfm), pure tungsten (3/32"), 5356 filler (3/32") welding 5052 or 6061 aluminum (not sure which because it was just a scrap, but I am guessing the latter of the two) @ 100amps max (75% AC waveshape balance, 120Hz).
I appreciate any thoughts, thanks!
-Scott
Old May 29, 2006 | 05:26 PM
Motorhead_AZ's Avatar
Default Re: Learning TIG + aluminum (WhiteSol)
They're too hot. How thick is the piece?
Old May 29, 2006 | 06:08 PM
Lamchop0000's Avatar
your ac balance is way to high... try it down at 20% or 30%
Old May 29, 2006 | 06:36 PM
WhiteSol's Avatar
Default Re: Learning TIG + aluminum (Motorhead_AZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motorhead_AZ &raquo;</TD></TR><TR><TD CLASS="quote">They're too hot. How thick is the piece?</TD></TR></TABLE>
It's thin, probably 0.050" or less. I was thinking it was way too hot also because of the dull look to it. Thanks for your advice!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N &raquo;</TD></TR><TR><TD CLASS="quote">your ac balance is way to high... try it down at 20% or 30%</TD></TR></TABLE>
Will do, thanks!
Any recommendation on amperage?
Old May 29, 2006 | 06:44 PM
fulldragcrx's Avatar
get rid of the pure tung.
Old May 29, 2006 | 07:21 PM
WhiteSol's Avatar
Default Re: Learning TIG + aluminum (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">get rid of the pure tung.</TD></TR></TABLE>
For a zirconiated tungsten? Please explain
Old May 29, 2006 | 07:30 PM
pure has terribul amp carring charateristics, read the miller book for rec on tungsten selection for a dynasty. inverters will like diff tungstens than transformer machines, so I would be careful what you read cause most welding books that are out there are refering to transformer type machines not yours. but i would think you could weld anything you wanted with a 3/32 2% thorated with a sharp tip, with that machine.
Old May 29, 2006 | 07:44 PM
WhiteSol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">pure has terribul amp carring charateristics, read the miller book for rec on tungsten selection for a dynasty. inverters will like diff tungstens than transformer machines, so I would be careful what you read cause most welding books that are out there are refering to transformer type machines not yours. but i would think you could weld anything you wanted with a 3/32 2% thorated with a sharp tip, with that machine.</TD></TR></TABLE>
Ah I see, thanks for explaining that. I have the miller TIG handbook which suggested pure tung for aluminum, but did not specify any inverter or transformer based machine differences. I have 4 or 5 types of tung I can try including thoriated.
Old May 29, 2006 | 09:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteSol &raquo;</TD></TR><TR><TD CLASS="quote">
Any recommendation on amperage?</TD></TR></TABLE>
The "rule of thumb" for aluminum is 1 amp per .001" of thickness, so you should be running around 50 amps.
As far as tungsten, use a red one. It works great.
Old May 29, 2006 | 09:42 PM
all_motor_mike's Avatar
ive used 2% and 100% on aluminum and i really cant tell any difference between the 2
now i also have a question......... how do u adjust the ac balance? there are alot of dials and **** on this damn machine and i dont know what any of them do. how do u do adjust for more "cleaning" (whatever that is) or more "penetration". u know what im talking about? its funny cause im pretty good at welding aluminum (and im alright at stainless) but i have no idea how to adjust the machine for different settings, welding conditions, etc. all i know is i use ac and high frequency for aluminum and i turn the high frequency off and use dc for steel. any help and understanding would be great.
mike
Old May 29, 2006 | 11:30 PM
WhiteSol's Avatar
Default Re: Learning TIG + aluminum (all_motor_mike)
Here's how I understand it..
More electrode positive gives a greater cleaning effect, and more electrode negative gives deeper penetration. On my welder I can adjust three settings, the %electrode negative or %EN (range between 30% - 90%), balance (65%-80%), and AC frequency(20-250Hz).
Basic rule for the first two is the more electrode positive, the more cleaning effect it will have. For frequency the higher it is, the narrower the arc cone. %EN adjusts duration that the electrode will be negative during one 360 degree squarewave cycle, and current balance controls the amperage while the electrode is negative.
Anyone feel free to correct me if my understanding of that was incorrect
Old May 29, 2006 | 11:59 PM
k24em2's Avatar
Your filler is too thick for that thin of material. Use 1/16" filler on that thin stuff. The beads should be shiny when done right. Using a Dynasty 300 I use 1.5% Lanthanated for everything, sharped to a point. Pure on the inverters can cause problems with the machines.
Old May 30, 2006 | 08:37 AM
wickedEG's Avatar
so the same set up I use to weld mild and SS I can use for aluminum (red tungsten with a sharp tip, AC)?
Old May 30, 2006 | 09:13 AM
Default Re: Learning TIG + aluminum (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Pure on the inverters can cause problems with the machines.</TD></TR></TABLE>
he's right, if you have a inverter, dont use pure tungsten! its written in the miller book!
use ceriated, thorated, or lanthanated for most welding.
Old May 30, 2006 | 11:35 AM
k24em2's Avatar
Default Re: Learning TIG + aluminum (wickedEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEG &raquo;</TD></TR><TR><TD CLASS="quote">so the same set up I use to weld mild and SS I can use for aluminum (red tungsten with a sharp tip, AC)?</TD></TR></TABLE>
I like lanthanated personally. But yea you can use the same setup.
Old May 30, 2006 | 02:42 PM
essex's Avatar
Hi , is that aluminum anodized? It looks like it ...if it is it might be worth it to get your self some nice clean 6061 to weld on instead of scrap that your not sure what it is.
- Dynasty 200dx uses a Lanthanated tungsten or Ceriated....Miller says not to use pure or anything else on it.
- Turn down the balance to 68 or 65
- don't ball the tip , or you'll run into HF start problems Keep it sharp with a little flat on the end.
Old May 30, 2006 | 06:37 PM
drumking15's Avatar
if i only had some time before my cra had to be up and running...id be more than glad to let you practice on my alum a/w intercooler...i need some tanks welded in different spots and about 8" of bead to reseal everything
Old May 30, 2006 | 08:47 PM
WhiteSol's Avatar
Default Re: Learning TIG + aluminum (essex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by essex &raquo;</TD></TR><TR><TD CLASS="quote">Hi , is that aluminum anodized? It looks like it ...if it is it might be worth it to get your self some nice clean 6061 to weld on instead of scrap that your not sure what it is.
- don't ball the tip , or you'll run into HF start problems Keep it sharp with a little flat on the end.</TD></TR></TABLE>
Thanks for the advice and for the info on the tungsten, it turns out that my owners manual fails to mention anything about the wrong types. I found the info online aswell under the miller site - http://www.millerwelds.com/pdf/gtawbook.pdf.
The aluminum is not anodized. However I did apply a deoxidizing cleaner beforehand which accounts for its strange appearance. I have some 6061 that I will be welding up once I get some of the settings worked out.
Thank you all for your input!
Cheers,
-Scott
Old May 30, 2006 | 09:03 PM
wickedEG's Avatar
Default Re: Learning TIG + aluminum (Lam.N)
use ceriated, thorated, or lanthanated for most welding.</TD></TR></TABLE>
How do you know if you have a inverter? I have a Lincoln Precision Tig 185.
Old May 30, 2006 | 10:00 PM
WhiteSol's Avatar
Generally you can tell by current draw.. The Lincoln PT185 is rated at 32A@230VAC whereas the Dynasty 200dx is rated at 15.8@230VAC. I'm guessing the lincoln does not use a inverter power source.
Gtaw Power Source guide
Old May 31, 2006 | 12:16 AM
yeah im still a little lost on when u would want to adjust for max cleaning and penetration???
Old May 31, 2006 | 12:26 AM
ok im gonna take a pic of my machine, then welds some beads, take pics of them and post them so u guys can tell me whats going on here. al3 and stainless.
Old May 31, 2006 | 04:00 AM
k24em2's Avatar
Precision TIG is a transformer.
Dynasty is an inverter.
The Lincoln inverters are called Invertecs.
EatSleepJDM
Welding / Fabrication
13
Feb 13, 2009 02:54 PM
---NON-VTEC---
Jul 9, 2007 04:01 AM
lohatch
11
Jun 23, 2006 07:41 PM
95lstegman
Jun 9, 2005 02:14 PM
Tinker219
Feb 27, 2003 10:27 PM
