NEED HELP ASAP!!!!!! ECU FUSE KEEPS BLOWING!!!
Old May 29, 2006 | 02:29 PM
93NTEGLS's Avatar
Default NEED HELP ASAP!!!!!! ECU FUSE KEEPS BLOWING!!!
I have a 93 integra ls and recently my 10A ecu fuse started blowing. I would replace it with a new fuse and as soon as I put the new fuse in, it blew again. please advise. thanks for the help
Old May 29, 2006 | 02:36 PM
mr.beeks's Avatar
Default Re: NEED HELP ASAP!!!!!! ECU FUSE KEEPS BLOWING!!! (93NTEGLS)
you may have a short somewhere along the ecu power line...
trace it from under the hood first...
Old May 29, 2006 | 02:38 PM
93NTEGLS's Avatar
the ecu fuse
Old May 29, 2006 | 04:41 PM
94rs-turbo's Avatar
yep check your grounds and for loose wires
Old May 29, 2006 | 05:40 PM
Kavehman's Avatar
id try putting in a 15amp fuse, but no higher.
If that blows then youhave a short somewhere, or a faulty ground.
Check all the grounding points in the engine bay
Old May 29, 2006 | 05:44 PM
93NTEGLS's Avatar
thanks for all of the help. i checked all of my wires for shorts and it was my o2 sensor wire grounding off on the header.
EGKREW
Dec 20, 2008 05:25 PM
Accord15
Oct 18, 2005 09:24 AM
Accord15
Oct 14, 2005 08:57 PM
Metal_SOL
15
Sep 9, 2002 09:41 PM
Metal_SOL
Sep 8, 2002 08:31 AM
