Engine Gauge keeps going above normal almost to red Please Help
I have a 1993 Accord Coupe EX and when it's very hot outside my guage will go past normal almost to red. I pulled over and left the car running and checked to make sure my fan was running it was. I have replaced the thermostat with a Honda factory one and drained the raidiator fluid. Eventually the guage will go back down but sometimes when I sit in traffic it goes up towards red. Please Help.
Here is a troubleshooting link. Hope it helps you find the problem. Good luck
http://techauto.te.funpic.org/overheating.php
make sure that BOTH fans are coming on..especially the radiator fan ( passanger side )
Both fans are suspose to run when the engine gets hot? Only one is. the one next to the battery. I thought only one is and the other comes on when you run the AC
It's in the link I gave you in the post above. Just follow the troubleshooting if this does not do the trick. Good luck again
Here's the link again. Click please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rardyboy »</TD></TR><TR><TD CLASS="quote">Both fans are suspose to run when the engine gets hot? Only one is. the one next to the battery. I thought only one is and the other comes on when you run the AC</TD></TR></TABLE>
yep both fans are supposed to be on when engine gets hot ,,
and both fans are supposed to come on with the a/c on..
crx6662
Dec 19, 2013 11:30 PM
