Running a b18a 90-91 throttle body on a b18b intake manifold
Old May 29, 2006 | 11:40 AM
unknown0001's Avatar
Default Running a b18a 90-91 throttle body on a b18b intake manifold
Hey guys I'm getting reading to finish my swap and I can't find a b18b throttle body locally.
I went to the wreckers and got a 90-91 integra throttle body and I'm just wondering will I have any problems using the OBD 0 throttle body with the wiring or vacuum lines on my OBD 1 civic with b18b engine/intake manifold.
I tried searching but haven't found a thread that could answer my question.
Thanks
Old May 29, 2006 | 12:45 PM
BOOSTED RIVAL's Avatar
Default Re: Running a b18a 90-91 throttle body on a b18b intake manifold (Mr.RHTuner)
No you will be upright but the problem is you will not have a fast idle because the B18B fast idle is on the throttle body and the B18A is on the modifold. I run my setup once like that too can't find my 94 ls throttle body but it work.
Old May 29, 2006 | 12:57 PM
Default Re: Running a b18a 90-91 throttle body on a b18b intake manifold (BOOSTED RIVIL)
What would the fast idle do for me? give me the option of adjusting the idle speed?
Old May 29, 2006 | 01:29 PM
the fast idle is just for moring or cold start to keep the rpm high.
Old May 29, 2006 | 01:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVIL &raquo;</TD></TR><TR><TD CLASS="quote">the fast idle is just for moring or cold start to keep the rpm high.</TD></TR></TABLE>
ah yea read it in a thread a few min ago.
I belive I'm safe without the fast idle, just need to block the port
Old May 29, 2006 | 01:58 PM
Is your map sensor on the firewall if not you will need a map sensor for a 92 honda civic because the B18a map sensor is on the fire wall but the B18B map sensor is on the throttle body.
Old May 29, 2006 | 02:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVIL &raquo;</TD></TR><TR><TD CLASS="quote">Is your map sensor on the firewall if not you will need a map sensor for a 92 honda civic because the B18a map sensor is on the fire wall but the B18B map sensor is on the throttle body.</TD></TR></TABLE>
Oh that I know, I already have the 2 map sensors, one for the firewall and one for the Throttle body
Old May 29, 2006 | 03:04 PM
projectTeG's Avatar
it will bolt up, but you will have a leak due to the fitv
Old May 29, 2006 | 03:37 PM
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">it will bolt up, but you will have a leak due to the fitv</TD></TR></TABLE>
Would you know exactly where the FITV port is located ?
Old May 29, 2006 | 03:50 PM
projectTeG's Avatar
Default Re: (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Would you know exactly where the FITV port is located ?</TD></TR></TABLE>
you on the b18a manifolds its located on the side of the IM, but on the b18b its on the TB itself, so it has a vaccum feed that you wont beable to block off if you use the A1 TB.
Old May 29, 2006 | 04:06 PM
it will not leak because the throttle body for the B18A is solid but for the b18b the fast idle is bolt underneath the throttle body, And I have done it all my motor.If it leak then I will not see boost.
Old May 29, 2006 | 04:37 PM
you on the b18a manifolds its located on the side of the IM, but on the b18b its on the TB itself, so it has a vaccum feed that you wont beable to block off if you use the A1 TB.</TD></TR></TABLE>
Re-read my thread...I have a b18b intake manifold and I just got a b18a1 throttle body
Just wondering if anybody knows where the port/lines are on the throttle body that I need to block?
Old May 29, 2006 | 06:06 PM
bobukler's Avatar
on my stock B18a1 intake manifold theres 2 wholes ( one for the tps, the other for the fast idle).......i noticed on the skunk2 or blox intake manifold theres only one hole (which is for the tps).......do those not use a fast idle or something?
Also......on my intake manifold theres a EGR valve......but on the skunk2 an blox theres no flange for it....i just want to understand this all.
Ive been having the same problem....please help
Old May 30, 2006 | 10:52 AM
Default Re: Running a b18a 90-91 throttle body on a b18b intake manifold (bobukler)
dam, we both have this problem
Old May 30, 2006 | 12:03 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Re-read my thread...I have a b18b intake manifold and I just got a b18a1 throttle body
Just wondering if anybody knows where the port/lines are on the throttle body that I need to block?</TD></TR></TABLE>
you cant block them because they are inter-grated inside the manifold and is meant to work with the B1 Tb.i wish i had my old A1 manifold so i could get you a pick comparing them.
http://www.ff-squad.com/tech/tb/tb.nofitv.jpg
http://www.ff-squad.com/tech/tb/tb.fitv.jpg
see the differnce?
Old May 30, 2006 | 12:53 PM
see the differnce?</TD></TR></TABLE>
Ok I see the difference, but that means the FITV is on the b18a manifold...so what if I just bolted up my other b18a manifold to run it with the throttle body?
I do have a spare b18a intake manifold but is there a difference in the runner length/dimensions between the b18a and b18b manifolds? I'd like to keep as much power available with the motor.
Old May 30, 2006 | 01:59 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Ok I see the difference, but that means the FITV is on the b18a manifold...so what if I just bolted up my other b18a manifold to run it with the throttle body?
I do have a spare b18a intake manifold but is there a difference in the runner length/dimensions between the b18a and b18b manifolds? I'd like to keep as much power available with the motor.</TD></TR></TABLE>
i believe that the 92-93 manifolds have the same runners and plenums as the 94+, the 90-91 is smaller.
Old May 30, 2006 | 02:29 PM
i believe that the 92-93 manifolds have the same runners and plenums as the 94+, the 90-91 is smaller.</TD></TR></TABLE>
dam that sucks
either run the proper IM and have the smaller plenum or run the correct IM and have the wrong tb lol
peteyparado
May 13, 2013 06:35 PM
PR8urVtec
Feb 4, 2013 02:05 PM
CSHornet60
11
Apr 14, 2007 08:05 PM
Laosakademiks
Oct 21, 2006 10:18 PM
King-Kong
Nov 30, 2004 12:48 PM
