Need opinions on possible oil issue!!.... thanks
Old May 29, 2006 | 11:09 AM
divingcorners's Avatar
Default Need opinions on possible oil issue!!.... thanks
Alrite, so i just got my b18c spec-R motor and it's burning oil. Mainly when i beat on it really hard. I did a leak down test and got less than 2% difference on every cylinder. YET, i have a couple people telling me it's valve seals, and others telling me it's piston rings.
THe motor still makes a ton of power. I am just inquiring as to what are the signs of both of these burning possiblities.
Any help you have would be greatly appreciated... thanks!
Old May 29, 2006 | 12:49 PM
EG civic's Avatar
Default Re: Need opinions on possible oil issue!!.... thanks (divingcorners)
Do the leak down test and after u fill up one of the cylinders, then listen by the throttle body and if u hear air escaping its ur seals, and if theres no air escaping open the radiator cap and see if there is bubbles in the coolant. That would tell u ur head gasket is bad. and if u dont hear air escaping or see any bubbles its ur rings.
Old May 29, 2006 | 03:03 PM
Default Re: Need opinions on possible oil issue!!.... thanks (EG civic)
well, when i did the leak down everything was solid, no bubbles or air escaping through the throttle body... so that means piston rings right? how bad is that... and how much does it TYpically run to fix that?
asondemitri
Jan 2, 2012 05:14 PM
kornkid21792
Feb 20, 2010 09:18 AM
Jackal6042
12
Jul 24, 2009 10:06 AM
hornetd23
Nov 11, 2008 05:51 PM
FastNFurious
May 20, 2003 04:29 PM
