starting problems, HELP ASAP PLEASE
Old May 29, 2006 | 10:41 AM
whophlungpoo's Avatar
Default starting problems, HELP ASAP PLEASE
Once upon a time, my car started fine one morning, then in the afternoon it took awhile to start, and finally that night it would not start at all.
So figuring it was the starter, because when i turned the key all i heard was a click then nothing but the lights and everything else would stay on. So i replaced the starter, re-connected all three wires, bolted the two bolts, checked the fuses, and still did the same thing.
Then I moved my attention upon the battery/battery connections. The battery turns out sucked *****, so i replaced that with a new battery. And then tried to start it, and still the same thing.
So i am at this current moment, needing the car ASAP. The fuses, battery, and starter are all fine. The man at advanced auto, whom inspected my work, said it might be the ignition/starter fuse or switch, but I have no idea how to replace that or even check and see if it has gone out.
So what do you think of my predicament?
________________
The car is a 90 CRX Si with a b16a, battery is in the back
Old May 29, 2006 | 10:43 AM
crx_88_si's Avatar
Main Relay.
do a search you will find PLENTY of topics.
morning = starts no problem, afternoon (when its warmer outside) its a pain in the but to get going right?
Old May 29, 2006 | 10:50 AM
Default Re: (crx_88_si)
Well now it is not starting at all, but the day it did start it was having very slow starts. And it roll starts fine
Old May 29, 2006 | 10:59 AM
Lil Red CRXsi's Avatar
Default Re: (whophlungpoo)
You need to replace the Ignition wiring harness
Old May 29, 2006 | 07:39 PM
Default Re: (Lil Red CRXsi)
bump
honda001
Acura TL, RL & ZDX
Sep 20, 2013 06:59 PM
eric416
Jun 22, 2004 09:33 AM
bluesaint
12
Mar 18, 2003 11:53 PM
Superhatch
Dec 24, 2002 02:36 AM
