will an 87 crx door fit on an 84crx? (looks a bit longer)
Old May 29, 2006 | 10:22 AM
EnSAn's Avatar
Default will an 87 crx door fit on an 84crx? (looks a bit longer)
reason i'm askin is i picked up in 84 and the drivers door is all jacked up. i noticed on the door it' marked '87 crx (prolly from a yunk yard) Anyhow I can't get it to line up there fore it wont shut all the way. I have a freind with an '84 door. But before i bug him about it i wanted to ask my question first. Cus if the 87 door would fit then there is something far worse then my door problem i'm guessing..
Old May 29, 2006 | 12:24 PM
ESS_Eisenkreuz's Avatar
what do u mean jacked up? scratched up? dented up? yea im pretty sure it wont.
Old May 29, 2006 | 04:21 PM
EnSAn's Avatar
Default Re: (ESS_Eisenkreuz)
Jacked up = wont latch or even come close to fitting. The owner had taken out the striker and the dome light switch and just tied the door shut. I unbolted the bolt connecting the door to the frame to slide it over closer to the fender, but i still can't get it to line up with the striker. I took the striker off from the passanger side just to give it a try. I'm hoping they maybe diffrent. Anyhow with the door slid as far foward as i can i still can't get enough room to get the door to shut all the way with the striker on.
turbo sol
16
Mar 12, 2019 08:14 AM
DTMkarnage
Jun 15, 2010 01:02 AM
suhteevin
Jan 6, 2009 09:04 PM
Bnjmn
Jun 6, 2002 07:15 PM
