ECU Pin for o2 sensor PR3 JDM B16A swap I NEED TO KNOW ASAP
Old May 29, 2006 | 09:26 AM
Jose-aka-Pedro's Avatar
Default ECU Pin for o2 sensor PR3 JDM B16A swap I NEED TO KNOW ASAP
Hey guys, Swapped a JDM b16A With y1 tranny into my Da9,
I'm hooking up the second o2 sesnsor, so I'm just going to run it off the first one,
that way I can use my aftermarket header
What wire on the ECU plugs is for the 1st o2 sensor?
I need to know ASAP. Please
Thanks, Jose
Old May 29, 2006 | 09:32 AM
projectTeG's Avatar
you get your timing problems worked out?
Old May 29, 2006 | 09:34 AM
Default Re: (projectTeG)
nope, having to set up an apointment with a guy localy, its off by a tooth,
I just need to get this wire for the o2 hooked up, I dont go anywhere coming from a stop, it takes forever to move
Old May 29, 2006 | 09:41 AM
mymeatb18
Default Re: (Jose-aka-Pedro)
go to g2ic.com and under tegtips you look for ecu pinout and it should be there i would tell you myself but my internet is being gay and wont let me go there
Old May 30, 2006 | 09:24 AM
Default Re: (mymeatb18")
yeah I already did that and it only shows the pin for the second o2 sesnor.
ANd I need the first. and its doesnt show the pins for the no-vtec ecu's,
Cmon~!
Old May 30, 2006 | 09:30 AM
aeon's Avatar
try http://technet.ff-squad.com/
Old May 30, 2006 | 10:34 AM
mymeatb18
well if you are using the stock ls harness then you can just runit to the o2 wire and your done but if your using the b16 harness i think the 1st o2 sensor is the one on the left. or just troubleshoot and see which one makes the car run like **** then thats the 2nd o2 wire
Old May 30, 2006 | 03:57 PM
yeah, thats what I was going to say.
I'm just going to cut into the wire about a foot away from the o2 sensor,
cut, splice, solder and tape,
Thanks
rage4theused
20
Jun 9, 2014 04:20 PM
BanEL
May 25, 2010 06:05 PM
Jose-aka-Pedro
May 26, 2006 06:19 PM
T_Rex
14
Sep 21, 2002 07:28 PM
Atiyeh
Jul 12, 2001 06:10 PM
