Sticky Throttle
Finally got my car back from body shop. I can't do that kind of stuff.
Throttle hangs up when first pushed down. Makes it a bit difficult to get the car moving graciously. Middle range of throttle is fine. Just the first application of pressure on the gas pedal.
Can it be the cable, and can it be lubricated?
89 CRX dx
Thanks for the insight in advance
89 CRX dx
Get some Honda Throttle Body cleaner, cause that stuff is the ****. Get a rag and spray the TB cleaner on the rag and wipe the inside of the Throttle body bore and plate off. DONT USE A WIRE BRUSH. Then Clean off the cable. Apply some trans. fluid to the cable where it hooks up to the throttle body. Check adjustemt. Done.
frostcivic
Oct 12, 2004 03:52 AM
