Oil Pump leaking
Old May 29, 2006 | 05:42 AM
teler86's Avatar
Default Oil Pump leaking
So i installed my b16 motor in my crx and it looked like the oil pan was leaking, i replaced the oil pan gasket twice, but it was still leaking. Next i have someone come over my house and see what they think i could do to stop the leak and they said it was not the oil pan, but it was the oil pump leaking, so he helped me take off the oil pan, he put a layer of rtv on the oil pump, and it held up for the night (or at least i thought so it was dark i could not really tell). So now it is leaking again . do you guys have any idea on how to finally fix this issue and actually enjoy my swap. i would really appreciate any advice.
thanx
Roman
Old May 29, 2006 | 05:45 AM
crxnj's Avatar
Default Re: Oil Pump leaking (teler86)
maybe the o-ring ?
Old May 29, 2006 | 07:36 PM
teler86's Avatar
Default Re: Oil Pump leaking (Mr.speaker)
is the o-ring inside the oil pump, aslo any other ideas????
Old May 29, 2006 | 07:40 PM
trrbl1bmx's Avatar
oil pump seal maybe?
Old May 29, 2006 | 07:56 PM
SIXTY's Avatar
Default Re: (ilovemyef9)
I had a similiar problem earlier this year, there is a small o-ring in the oil pump that goes around the small inlet/outlet on the upper left hand corner of the oil pump if you were looking at the back of it. Also when you use the RTV sealant make sure you let that stuff cure for at least a whole day, i learned that the hard way. Good luck.
Old May 29, 2006 | 08:43 PM
mahatma's Avatar
Default Re: (sixty-seven point six)
The o-ring is very easy to overlook. I had my engine all the way together before I realized wtf happened....
Old May 30, 2006 | 11:51 AM
teler86's Avatar
Default Re: (mahatma)
can i buy it seperate or do i have to buy the whole oil pump
Old May 30, 2006 | 11:53 AM
SIXTY's Avatar
Default Re: (teler86)
You can buy it seperate, it is like something really cheap at the honda dealer. Less than two bucks.
Old May 31, 2006 | 05:06 AM
teler86's Avatar
is there any other rubber seals in the oil pump except the o-ring?
Old May 31, 2006 | 08:54 AM
teler86's Avatar
after looking at it in the garage i realized it does not leak at idle but only after you let off of the gas does this still sound like the o-ring.
somick
Aug 15, 2017 08:14 AM
Tzarinque
Sep 19, 2008 09:59 PM
leighton1245
Apr 10, 2008 10:47 AM
Maxboost00
Oct 19, 2004 08:59 AM
iwouldHITit
Jul 17, 2003 04:11 AM
