98 ls in eg check engine light on?
Old May 29, 2006 | 12:39 AM
josueHB's Avatar
Default 98 ls in eg check engine light on?
I droped a 98 ls did the whole OBD I swap but now i dont know why my engine light is on i have seen others with the same set up but no problems and also at start up it sputers until it gets to normal driving temp what is wrong?
Old May 29, 2006 | 01:12 AM
Eran's Avatar
HT White Ops
have you bothered to check the cel code?
Old May 29, 2006 | 01:13 AM
teknoracing's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">have you bothered to check the cel code?</TD></TR></TABLE>
Seriously, it would help out a lot. That CEL is probably why your engine sputters.
Old May 29, 2006 | 01:51 AM
fmrprojects's Avatar
Default Re: (teknoracing)
when i ran my 96 LS in my 95 hatch, i had the same problem. but i used everything obd-2 except the ecu. in the mornings or warm up it idles real low, but then when it warms up its good to go
doja
Jan 22, 2011 08:38 PM
boostedteg4dr
Jan 6, 2008 11:31 PM
civicb16eg
Mar 28, 2005 02:16 PM
c8r9x
Jul 6, 2004 10:24 AM
davidjaii
Oct 20, 2003 02:46 PM
