question about compression???
Old May 29, 2006 | 12:17 AM
89hatcher's Avatar
Default question about compression???
i just did a compression test on my b18a1 motor and it says #1-175psi, #2-175psi, #3-150 and #4-175...could my valve seals cause my #3 cylinder to have a low psi and also is 175 psi low for my compression for my LS motor? any help would be appreciated...thanks in advance
Old May 29, 2006 | 12:43 AM
SD_Lurker's Avatar
HT White Ops
Default Re: question about compression??? (89hatcher)
Time for a rebuild depending on whats causing you to lose compression.
Old May 29, 2006 | 02:41 PM
89hatcher's Avatar
so is 175 psi not enough compression for an LS motor?
88 civic
Apr 5, 2009 03:21 PM
CNSK
May 24, 2003 03:26 PM
dho311
Nov 10, 2002 06:30 PM
