Hytech Production Header Polish?
Well, my car is down for the count, and I thought I would polish my hytech production header...
It doesn't look "that" bad, but I miss how it looked when I first got it. One thing I was concerned about is if it's coated with something that I should try not to sand off?
Would it be more protected from the elements if I just left it as is?
https://honda-tech.com/zerothread?id=1563439&page=1
i got great results from following this thread, header looked brand new after i was done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circa »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1563439&page=1
That is actually one of the more recent threads I ran across about polishing a header.
I'm concerned about a protective coating, if any on the hytech header that maybe I should avoid sanding off.
</TD></TR></TABLE>That is actually one of the more recent threads I ran across about polishing a header.
If you want the lazy process. Take the header off and have it jet-coated. You will never have to worry about polishing it again, since the coating makes it look like new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara »</TD></TR><TR><TD CLASS="quote">
I'm concerned about a protective coating, if any on the hytech header that maybe I should avoid sanding off.</TD></TR></TABLE>
hmm is the coating irreplaceable?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circa »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1563439&page=1]
I used this method and though time consuming, it works great. I should add that I went a step further and for my final sanding I used 1600grit to make sure there were no swirl marks in the stainless.
</TD></TR></TABLE>I used this method and though time consuming, it works great. I should add that I went a step further and for my final sanding I used 1600grit to make sure there were no swirl marks in the stainless.
pomansouth01
23
Jun 19, 2007 11:49 PM
