Need Help NOW!!!!
i have a b16 in my 89' si and it didn't run right one day and i figured out that one of my injectors had shorted out.. so i replaced it and it started and would idle fine... now its came to another problem.... it will start and idle but when i give it any throttle it bogs and cuts out and will not rev past 2500 rpms. i have put in a new o2 sensor, fuel filter, new plugs, plug wires, distributor, cap and rotor, knock sensor.... but it isn't throwing any codes...i had a guy tell me that it was my TPS but i changed it out with a different throttle body and it didn't make a difference...and i had a buddy of mine say it could be a plugged cat, but what do you think???? I'm out of options and need help please.... could it be a problem with my fuel system becuase just before it started this mess, my gas gauge stoped working????
i had a similar problem with my crx si w/jdm b16. It wouldnt rev past 3500. ultimately it was my ecu. I converted it to obd1 and threw in a stock p30 and it was fine. Try pluging in a different ecu./
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bustinvtec »</TD></TR><TR><TD CLASS="quote">i had a guy tell me that it was my TPS but i changed it out with a different throttle body and it didn't make a difference...</TD></TR></TABLE>
If you're throwing a TPS code, you need to adjust it.
.45-.5v closed throttle
4.5-5.0v open throttle
rice_classic
Nov 11, 2003 07:06 AM
