EVAP Purge Solenoid Valve help...
Old May 28, 2006 | 09:02 PM
ch00dlz's Avatar
Default EVAP Purge Solenoid Valve help...
There are hundreds of honda Techies here! Thanks for the tips and I appreciate all help
The JDM Intake manifold for a B16A intake manifold is missing a port for the EVAP Solenoid Valve hose....
What should I do w/this? Some say to plug the hose. I'll take all support here, thanks!
Old May 28, 2006 | 09:57 PM
Out of every
Default Re: EVAP Purge Solenoid Valve help... (ch00dlz)
plug it. i dont have one on my jdm motor
Old May 28, 2006 | 10:46 PM
Jedi_Sol's Avatar
Default Re: EVAP Purge Solenoid Valve help... (e gee two)
Unless you are worried about passing emissions, you don't NEED the evap purge.
Old May 29, 2006 | 06:55 AM
ch00dlz's Avatar
Default Re: EVAP Purge Solenoid Valve help... (Jedi_Sol)
So then, it should be plugged?
What is its purpose?
Modified by ch00dlz at 8:28 AM 5/29/2006
Old May 29, 2006 | 11:38 AM
Jedi_Sol's Avatar
Two functions:
1) Prevents fuel vapors from escaping into the atmosphere by...
2) Temporarily storing fuel vapors in the charcoal canister, then the Evap purge valve will purge the vapors into the engine so they can be burned.
Old May 29, 2006 | 11:43 AM
EK79's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two &raquo;</TD></TR><TR><TD CLASS="quote">plug it. i dont have one on my jdm motor </TD></TR></TABLE>
same here
Old May 29, 2006 | 07:30 PM
ch00dlz's Avatar
Thanks jedi. Good info!
Thanks for the help doods.
Old Aug 3, 2006 | 05:36 PM
WHAT TEH's Avatar
plug tha purge solenoid valve side or tha canister side? if tha canister side, can't we just leave it open? and if tha purge solenoid valve side, what about tha plug comin' from tha ECM (ECU)?
_taF
wasapyt
Jul 20, 2010 03:37 AM
RiversideS13
11
Jul 21, 2007 08:11 AM
gsr dood
Mar 20, 2006 07:24 PM
byronl
Mar 19, 2005 10:24 PM
Schaz
Jan 6, 2005 06:31 AM
