engine code for '94 accord exr?
Old May 28, 2006 | 09:01 PM
mg40's Avatar
Default engine code for '94 accord exr?
just bought the car and im planning to tune it, but i dont know where to start.
oh take note its autmatic(bummer).
needs some idea
Old May 28, 2006 | 11:09 PM
H2290's Avatar
Default Re: engine code for '94 accord exr? (mg40)
I assume you are from Canada or somewhere that has the EXR model that corresponds to our EX model. Well, having the auto sort of sucks BUT you may want to start with normal maintenance items and also do a compression check.
Old May 29, 2006 | 07:54 AM
d112crzy's Avatar
search.
Old May 29, 2006 | 11:23 AM
SummerTaz's Avatar
engine is probably f22b1
very similar to f22b2 but you have that little thing called VTEC
Old May 29, 2006 | 08:48 PM
mg40's Avatar
Default Re: (d112crzy)
hey thnx man,
ok my friend advise was to get a vtec controller.so that i can allow the vtec kick in @ 3000 rpm atleast. now do you have any pros and cons about this.?
Old May 29, 2006 | 11:06 PM
d112crzy's Avatar
yea, vtec on a sohc is one of the dumbest things honda could have ever done.
spend your money on something better. get real mods, then maybe that controller might do you better.
tell your friend to get a rope, hes a ricer.
Old May 30, 2006 | 03:07 PM
H2290's Avatar
A lower VTEC set point is not necessarily better. I believe anything like a VAFC should be set on the dyno. A little lower usually helps but going as low as possible doesn't.
mrbleh
Jan 15, 2014 03:03 PM
The(704)kid
Jul 5, 2011 10:19 PM
bocajoe
Jan 6, 2011 04:36 PM
chelsea
Sep 23, 2005 01:53 PM
jagged4698
Jan 25, 2004 06:09 PM
