HELP! can't get the ignition timing right on my car! 91 integra w/B20B
Old May 28, 2006 | 08:44 PM
600_Double_R's Avatar
Default HELP! can't get the ignition timing right on my car! 91 integra w/B20B
ok well i'm trying to fix this car i just bought. its a 91 integra with a B20B swap. i fixed the coolant leaks and now i'm trying to get the timing right but its not working! i put the cyl. 1 to TDC and made sure the dizzy rotor pointed towards the 1st spark plug cap...i made sure the marks on the pulley lined up with the indicator AND i made sure the "TOP" marks on the cam gears were facing up...then i put everything back together...started the car...and the "RED' middle mark on the crank pulley doesn't even come close to the indicated on the timing belt cover where u point the timing light gun! ANY SUGGESTIONS? cause i'm stumped! i even broke out the manual and followed it word for word! help me please!
Old May 28, 2006 | 09:06 PM
what if on the cam gears, the little marks on the teeth that your suppose to line up, didn't line up? like when your trying to find TDC and your suppose to make sure the "UP" marks on the cam gear are pointing up and your suppose to make sure the side marks on the cam gears are facing each other...well if they aren't facing dead each other is that bad? what would i need to do to fix this? loosen on cam gear to make if face the other one straight on?
Old May 29, 2006 | 06:31 AM
Sam92Teg's Avatar
Default Re: (600_Double_R)
When your cams are lined up at TDC and you look down at the crank pulley, which timing mark do you have lined up with the lower cover pointer?
Shikaido2004
Jun 27, 2008 07:32 PM
civiccoupe94
Jan 11, 2008 07:08 AM
Project_CD5
Jul 25, 2007 03:20 AM
civickiller
Mar 8, 2004 11:34 AM
