About to install McCulloch HID conversion kits, questions
Old May 28, 2006 | 08:15 PM
PaChiLa Leader's Avatar
Default About to install McCulloch HID conversion kits, questions
I would like to know after i installed the HID kit do i need to switch the fuses for the headlight or the Stock one is alright?
i bought a 5300k kit going to install on a 2000 integra if that helps
Thanks~
Old May 28, 2006 | 08:32 PM
Azn Kenny's Avatar
No need to switch fuses, HID's draw less power than halogens.
Old May 28, 2006 | 08:43 PM
Default Re: (LS-N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-N &raquo;</TD></TR><TR><TD CLASS="quote">No need to switch fuses, HID's draw less power than halogens.</TD></TR></TABLE>
ic.. thanks.. reason why i am asking is coz i remember read something somewhere that i will have to change the stock 15a to 20a or something..
Old May 28, 2006 | 10:10 PM
nautica_t's Avatar
thats correct you won't need to however a relay harness is always good on teh safe side.
and as a side note:
hids do draw less current except on initial start up they actually draw alot more.
remember its just not just heating up a filament, its sending power to the ballast to send a signal to the ignitor.
its liek a car battery during cold cranks and hot cranks. its easier during the summer cause its not requiring much work cause the battery isnt' cold, but its works harder during the cold days.
Old May 29, 2006 | 05:27 AM
Default Re: (nautica_t)
Thanks for the replies guys.. especially Nautica_T ... big thank you to you.. you helped me a lot
i am going install the kit tomorrow when it comes out from the garage.. iwill keep you guys posted
thanks a lot~
Old May 29, 2006 | 07:16 AM
KillrDAfromMars's Avatar
Default Re: About to install McCulloch HID conversion kits, questions (PaChiLa Leader)
You dont need to switch the fuses. I have had a McCulloch HID kit on my Lancer Ralliart for almost two years, no problems.
Old May 29, 2006 | 12:51 PM
nautica_t's Avatar
you're welcome, its always good to help other people out.
good.wil.tintin
Sep 23, 2012 03:46 PM
BFloFoxRider.
Lighting
Dec 14, 2010 01:28 PM
ml89
Jan 16, 2008 09:39 PM
XYU
Aug 22, 2006 04:36 PM
JDM_Type-R
Apr 8, 2002 01:22 AM
