VSS acting up... ANNOYING
Old May 28, 2006 | 07:51 PM
axtran's Avatar
Default VSS acting up... ANNOYING
when my car sits for a while then starts, my speedo doesn't work... i have to roll and furiously hit the trip meter reset for it to work again... think its because i tried to roll back my odo? hope i don't have to put the stock DX cluster back in.. that means ricer tach...
Old May 28, 2006 | 07:56 PM
JDM-EJ1's Avatar
Default Re: VSS acting up... ANNOYING (axtran)
I'd recommend checking your VSS sensor. Try cleaning it, that will fix it a lot of the time.
Old May 28, 2006 | 07:57 PM
fmrprojects's Avatar
odometer fraud, you could do some hard time for this. but if its your VSS check the connection on the back of the cluster or if the vss is still goood itself
Old May 28, 2006 | 08:00 PM
JDM-EJ1's Avatar
Default Re: VSS acting up... ANNOYING (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">odometer fraud, you could do some hard time for this. </TD></TR></TABLE>
Only if he sells the car. I've swapped so many clusters into my car I've lost track of how many miles my car has, but then again I don't ever plan to sell my car.
Old May 28, 2006 | 08:04 PM
axtran's Avatar
like hell i'm selling this car. I &lt;3 EG hatch. well, EH2. plus, new connector wire and new VSS... i'll have to check my crimping to make sure, lots of vibration could have fubared them. or i'll try the DX cluster for a while and if it doesn't happen with that thing i'm going to cry when i get a ricer tach. lol impossible to drive a GSR EG without a tach though
Old May 28, 2006 | 08:05 PM
JDM-EJ1's Avatar
Default Re: (axtran)
Try the other cluster, see if the problem corrects itself with the DX cluster. If it does, that tells us that your current cluster has a defective speedo. If it doesn't, I would look into your VSS.
Old May 28, 2006 | 08:10 PM
Paxil4x4's Avatar
Default Re: (JDM-EJ1)
Can't the speedos just be swapped in the clusters
Old May 28, 2006 | 09:00 PM
lcjarrett's Avatar
still having probs with my VSS...i swapped cluster with my wife and still no Speedo or Tach...I give up...hahaha
Old May 28, 2006 | 09:11 PM
axtran's Avatar
yeah screw VSS-es. i think i could have been when i was installing my radio i pulled the radio harness a bit it could have loosened the wire behind the cluster... will have to take it apart and check it tuesday when i'm off of work.. and time to install the a/c bracket too! wewt
virdizzeripsta
Jan 1, 2014 11:58 AM
civicEXtreme
Dec 15, 2007 03:10 PM
hondaboy4life
Oct 9, 2006 09:35 AM
HULKHATCH10
15
Jul 12, 2005 09:27 PM
thePHIG
Oct 13, 2004 10:46 AM
